Quick Burn in CD/file
bonzo75
25,671
16,962
4,490
London
Hi, is there any file I can run through a dac for a quick burn in of the system every time I come home?
Also does this work to burn in new speakers or amps as well?
Thanks - so where a system takes an hour to burn in, how much would this be? And at how much DB do you have to play it, can you play it at low volumes?
The first time you play the disk it should be at normal listening levels whereas subsequently it is played at a level where you can carry out a conversation. He claims just a 6 hour burn in is required
Can you or someone explain to me why this would need to be done each and every time?
Hi what about daily burn in, to warm valves and drivers, which normally takes about an hour? Can that be sped up, by playing only one track or some pink noise?
no need. Just turn on your components for 15-20 minutes. I use the burn in disk whenever I introduce something new to the system. and go through the 4 reps (6 hours). He also advises to play it once monthly. I never use it to warm up system. Warm up and burn in are two very different things
I don't burn it in every time I turn the system on. The IsoTek disc that I use is essential for me because of the number of shows that we do. I found (a number of years ago) that it makes a great difference when we run that overnight as compared to just playing music or white noise on repeat. So, it's part of my show routine to run that disc.
However, warming up the system when you turn it on everyday...... I don't play anything.
Hi, sorry, back to this thread for one question. If I have new speakers, and I want to run them in, can I keep either the Isotek or the PAD disc running in continuously for a week or so? Assume the speaker takes 300 hours to break in normally, will these discs halve the time that way?
Yes - but it won't halve the time, depending on the break-in disc. You may find that it also acquires the "sound" of the designer of the disc.
If the sound is irritating, wire one speaker out of phase, face them together and run the break-in disc. Obviously, this doesn't work for Genesis or mbl.
There are recommendations on the Gon for Ayre's Irrational but efficacious disc for the same purpose, but apparently if it's run loudly it can blow up the tweeters or other drivers.
Can the PAD or the Isotek be ripped and played through a computer file fed to a dac, or does it have to be through the CD?
I guess I can play it through the CD drive of the laptop
I do remember at one time the caution not to burn in with squarewaves as they were too different from music. So what is wrong with music for burn in? Oh you think you can use some special "hard core" signal and reduce the time for break in. Pretty damn funny that one. Is burn is better, quicker, of more quality (quality of what???) than regular music? Is it steeper edged, maybe you need slow tones to not upset the fragile nature of the system burn in is helping with. Anyone ever give any rational thought to what the heck is happening with burn in? Maybe sawtooth waves. Better than squarewaves or noise. A fundamental with all harmonics in a fourier series. A little bit more like musical signals only more so. Pink noise, why not pink noise, it also is a distribution of frequencies like music in a sense?
Why not just harden the eff up and play music till it sounds good? That way burn in, break in, listener acclimatization or baloney, you aren't wasting the life of your components on something dubious. Just play some music. Is it really that complicated? Just play some music.
