Mr Acoustat
So the Furutech looks a lot like the Hubell or is it the Hubell? Just trying to understand ...
Hi guys these are the receptacles i have been using since the early 80s, they are now more than 30 years old and the grip is as they where new
Are you certain, because every spec or hospital grade I've tried (many) seemed to show obvious fatigue within 5 years. However, considering the cost, it's not a big deal.
tb1
tb1
Wow, they spend big bucks on testing and even bigger bucks for documentation of hospital grade receptacle's.
Not sure way everyone is having so many problems with receptacle's. At work, at the test bench we plugged cords in 20 or more times a day and I don't recall any need for replacements.
SURPRISE! Your outlets are installed UPSIDE DOWN.
Hospital outlets are supposed to have the ground pin on top.
Take a look at Leviton's website: http://communities.leviton.com/serv...2099-102-1-3203/Spec All HG IG Receptacle.pdf
It is a safety factor for hospitals to have the ground prong on top.
Having the heavy, longer ground pin on top will also keep your heavy plugs from pulling out better.
I use 10 of the Furutech GTX-D Rhodium duplex outlets with the Oyaide Carbon Fibre frames and aluminum covers. yes, they are spendy. but they sound great.
here is a little test you can do. take one of these Furutech duplex outlets and any competing outlet. drop them both on a hard surface from a foot to 18 inches. the alternative will rattle and buzz. the Furutech will 'thunk' solidly. that is what also happens to the sound. the Furutech does not add resonance, the others do resonate and you can hear it. the Furutech also uses 6 '9's' copper for their clamps and a stainless spring behind it to insure the proper connection without scraping the surface of your plug. most others get their gripping strength from using alloys that don't conduct as well and scrape the surface of your plugs.
superior mechanical construction and metallurgy does cost more to make.
you get what you pay for.
You should have installed them before you dropped $15K on the Entreq boxes and cable.;-).
That is good to know. I need to try them.
PS- I installed them in my listening room two years ago.
I can tell you the Entreq and Furutech GTX-D Rhodium outlets are complementary; both get 'stuff' out of the way of the music!
With ALL those heavy power cords you need GOOD receptacles and you don't get those for $1.29
Hi guys these are the receptacles i have been using since the early 80s, they are now more than 30 years old and the grip is as they where new, cost was $131.00 for a box of 10 back then i would install them at friends houses.
PS: For 2013 this is the new kid in the bloc. wall plate - receptacle - cover - will cost you $450.00 + installation.
Hubbell HBL-8200HR
View attachment 8419 View attachment 8420
WHY OH WHY do any of those high priced outlets have score lines so you can break off the ears???
No one who buys those outlets are going to take them off in their installation.
