You must already be asleep and dreaming.
LOL, I have both formats well sorted, you do not. I am very comfortable with my judgment...But please, continue to grind away. This is getting humorous. Cheers !
Glad to know one person in the whole world has both formats sorted out! What you have sorted apparently can not be explained in the dynamic range comparison of digital and LP. Must be something else but you are not telling because......?
I just finished listening to Telarc full digital recording stereo cd-70501 California Project Papa Doo Run Run and it was recorded without limiting or compression and it sounds fantastic. Done right, and taking advantage of digital, and as Keith Johnson shows a few post up, digital is really great when done right.
I agree, it is! My digital music collection is very small and I only have a cheapie old H/K DVD/DVD-A/CD/SACD player, but the 20th Anniversary SACD of Dire Straits - Brothers In Arms kicks ass! I can only imagine what it would sound like on a top-notch digital setup.
Or the cheaper and at least as good sounding MFSL SACDYou should hear the recent SHM SACD of this title.
LOL, I have both formats well sorted, you do not. I am very comfortable with my judgment...(...)
And this is the vexing issue. And why is digital not done right. One suggestion I have seen numerous times on the web is that digital is mastered to sound good in a car while obviously vinyl (with a few goofy car record players) is supposedly mastered to sound good in your home, in a quieter environment. Also, I would say that you can only make vinyl so loud before its unplayable, while digital can be pounded to 0.001db or even clipped. And, also, supposedly audiophiles are such a small part of the market, perhaps less than 0.5% (my guess) that we don't matter. Hence the limited "audiophile grade" mastered stuff...
yes, it's all about loudness. ...
... If the labels cared about sound quality, they would make RTR master reel dubs available to the public for purchase. ...
I strongly agree.
Whew. How much do you think they would cost? How many people have good RTR decks?
I know what the generation loss of a real-time dub on a good studio deck sounds like. I'd much rather have a 24/96 digital dub.
I have all three SACD's: the 20th anniversary, the MFSL and the SHM. Compared to the 20th anniversary, the MFSL sounds a bit more refined, with a touch more clarity and detail, but it loses in punch and dynamics. Upon hearing both back to back, a friend of mine commented that the MFSL sounds like the unplugged version of the album. Choice between the two might as well vary with the system and individual preferences, but since this is a rock album and not a string quartet, I personally prefer the 20th anniversary. However, the SHM is way better than either of the other two.
Two huge problems with the SHM-SACD, IMHO. First, it has the truncated LP versions of the songs on side 1, a no-no in my book. Second, somebody turned up the treble rather remarkably; I guess if you don't hear the frequencies above 8 kHz it might sound OK, but otherwise...
The DR reading for the 20th Anniversary Stereo SACD layer is about 8, very compressed. The Mch layer is much better although still peak limited compared to the original CD or either of the other 2 SACD's (which are all about the same at 15-16).
It's a very tough choice between my original Vertigo CD and the MFSL SACD, but one or the other is my go-to.
I do not find the treble in the SHM SACD exaggerated and I do not think it is my hearing either, but you are certainly entitled to your opinion.
Also, where did you get the DR reading of 8 for the stereo DSD layer of the 20th anniversary SACD? The DR Database reports 8 for the redbook layer and 13 for the stereo down mix of the 5.1 DSD layer. Unfortunately, no data for the stereo DSD layer, which is the one I listen to. The DR for the stereo DSD layers of the MFSL and SHM SACD are both reported to be 15.
I think the facts have shown the dynamic range of cd, and no facts have shown the dynamic range of LP, and the facts have shown that LP playback (refer to the techdas cartridge measurements,, bottom of post 153) is a severe distorter of sinewaves compared with digital. It is well sorted, and it is sorted that distortion is preferred by many. So like, we did not already know that with SET amps. The conclusion to be drawn at this point, which is already known, is that playback LP is dynamic range limited vs digital. And the idea that a more distorted playback system can sound good suggests that stereo has some limitations that some need masking to better enjoy....buy hey, its an idea from the 1930's and even the inventor of it talked about some of its weaknesses...read his patent.
I strongly agree.
I note that the video shows a limited run pressing. The discs are apparently being pressed directly from stampers made from the lacquer master. You can only make one metal part ("master" or "matrix") from a lacquer. For longer runs, one or more metal "mothers" are made from the master. The stampers are then made from the mothers.
Lacquer (positive) is silver/nickel plated and the plating peeled off to produce a master (negative).
Master (negative) is nickel plated and the plating peeled off to produce mother(s) (positive).
Mother(s) are nickel plated and the plating peeled off to produce stampers (negative).
Stampers are usually chrome plated for wear resistance.
Stampers press discs (positive).
While a cut lacquer may have a low surface noise, each plating step introduces surface irregularities which accumulate, increasing the surface noise on the eventual disc.
A lot has happened in LP mastering since the 1930s! FWIW though if you run digital past its limits, the distortion is even higher! No relation to music at all.
Correction, since some of the above is incorrect: there were never any car record players. I have seen photos of one, but it never got past prototype. Digital can't be 'pounded or clipped' as you put it- that is the realm of analog. If you clip digital you stand a good chance of ruining the recording! Its just something you can't do. Spend some time with a digital recorder some time and see what it does.
Sounds like you don't know about the Tape Project (www.thetapeproject.com).
The 1-step process can get you between 500 and 1000 copies then its done. The 3-step process can get you millions. The noise seems to have more to do with the pressing machines than it does the metal parts in the process. This is why QRP pressings can be so quiet- they have less vibration during the pressing operation itself.
