I know it seems complex, perhaps it is. However, record IMD tones into a digital recorder at half full scale, and record into a cutter at half full scale for lp and then cut a record we can playback on our gear, and when you play back each and look at the results, the lp version will have more distortion. So, at some level, it has to be accepted that there is more distortion. Why it adds up to something we like is buried across a lot of threads we have here on wbf, atleast why we THINK it is so... your idea of a good study into this would be welcome and I think would finally allow digital folks to "duplicate" what is best about the LP sound for many.
Sure, but the problem is Keith Howard did some complex and better testing with various harmonic patterns, and in every case his conclusion was that distortion was always a negative.
He is not the only one and there has been a few comparable studies, but his approach could be applied to any music.
Unfortunately a lot of conclusions relating to distortion/harmonic patterns is based on a lot of circumstantial approaches; whether we are talking about sensitivity to harmonic distortion or preference to type of harmonic distortion patterns when applied to music.
We also hear a similar debate-case with tubes all the time; and yet it does not hold up when one looks into it in further detail and how this can be contradicted by the different performance between said top tube equipment.
Same is also said about white noise being audibly benign...... But then what about those (and I am one) who absolutely hates white noise when listening to music.
It is not possible to at present IMO to generalise about distortion/noise/etc and their real world influence on preference until studies are done with music that also is controlled (so has without and with distortion/noise variables and at various threshold levels).
Sorry if it seems I am being a bit picky on this subject, just I think it is a leap too far at this stage to say categorically the influence when applied to extended (not necessarily all at once) critical listening to music.
I can accept it is a position that is divided between members and that it is probably an agree to disagree proposition
And comes back to the dreaded trained listeners for studies-investigations
Thanks
Orb
