On the 810LP, see this http://www.whatsbestforum.com/showt...-Spectral-Gear&p=205362&viewfull=1#post205362
I found this nice little tutorial on shielding online if anyone is interested. http://www.learnemc.com/tutorials/Shielding02/Practical_Shielding.html
After reading the tutorial above I decided to mess around with some 1/2 inch copper foil tape I had bought awhile back. I decided to tape the seam of the bottom plate on my Lehmann SCR. The enclosure is all billet aluminum except for the bottom plate. I also covered the dip switches on the back, and the led light on front with copper tape. About all I can do that is practical.
So what was the result? Well before I did that I would get interference from my cell phone putting noise through the system if it got too close to the phono stage. After the tape I can now put the phone right by the phono stage and tonearm and get no noise from it.
very interesting...just so I get this straight...what exactly does one tape in your opinion? Any seam of the component? Why the LED light? Thanks for any guidance on this.
Hi Lloyd, well since this is my first crack at this sort of thing, I just did what made sense to me from reading the info in that link above. It says that the seams in the equipment can act as an antenna. Also holes in the case can let RF in. It's also important to use shielded cables in and out of the equipment. I know my tonearm wires are shielded but my interconnects coming out of the phono stage are not shielded. As far as covering up the LED not sure if that was necessary but figured I could block the light from being annoying as a bonus.
I can put up some picks of what I've done if you like?
The adhesive on this foil tape is not really aggressive so I'm not too concerned about it staying on the equipment when removed. If it does I can remove it pretty easily.
Thanks! The reason I was curious was the fact that you can hold a cellphone with no effect now. That is quite something...but given that you were taping edges...I thought...do I need to tape edges, holes around tubes, and all RCA inputs that are unused as well?
I would not try to seal up a tube based phono stage with copper foil tape. Unless the tubes do not protrude and do not need the ventilation. I would ask the designer first in that case. My SS phono stage does not need ventilation. The transistors are heat sinked to the aluminum case inside.
Here's a video of the completed analog rig shield I have implemented, mu-metal+copper foil throughout and routed to ground - as others have attested, the drop in noise and resulting improvement is simply staggering... a clear example of function following form.
I mean businessNo the tuner is dead quiet; unplugging or removing it makes no difference; it's an exceptionally well-shielded tuner. BTW, I recently added a Shunyata Defender to the same circuit with the tuner, phono and panels - and what a significant improvement that brought; e.g. there was some residual noise from the panels' power supply if you were to stick your ear on them - like hashies - with no music playing, but no more... tiny but important improvements.
