Fantastic...look forward to hearing more about it!!! Enjoy!
Hi
This saturday i will have one Q sub 15 in may home for some weeks to tried it
Hi
This saturday i will have one Q sub 15 in may home for some weeks to tried it![]()
Oh!!!...you did NOT just say that! Amazing! You MUST report in when you've got it set up!.
Yes i will![]()
Hi
I will get help from my Norwegian supplier of measurements and Sharing/Crossover ......
we will measure the room first and then measure when we calibrate the Q Sub. I am very excited about how linearly we will get when we use sub in may room. I think this will be quite goodI've got a program that I have inst alert on my computer when everything is controlled from the computer. There is a usb cable from the computer to the Q sub. Am very excited to test this, I've borrowed Qsub 4 weeks before I should decide if I will buy it. I would not buy it without testing it on my own equipment in my own living room with my own ears :May system are: Magico Q3/Burmester 069/911/077.
Sorry for may English, i am from Norway
Espen L
Hi
Hi...how is the QSub audition going? Most curious!!!
Hi
I will make a full and honest opinion on what I think about the sound in a week or two, so it will come I promise.
Espen
Hi
Then I had listened and tested Q15 Sub few days, just have to say that I am shocked how good this is. It has certainly lifted my system to new heights. Having tested a part of where the best crossover fit in my room on my Q3 and it looks like that 60 Hz is it my ears like best. Must rose Magico for the help I received via skype when there were things I was wondering in terms of DSP and other things. I especially sonically satisfied with how well Q15 glide rest loosely in the rest of the sound with my Q3. I'm shokk how good Q15 really is.There is very much filter / settings you can do so you have to adjust Q15 as one would like. I've got a tighter and more fuller bass so I'm very happy.
Thank you Alon/Yair/Magico for making this Sub
Sorry for my English.
Espen
Hi LL21
Yes've tested several previously tested Burmester S8 and Audio physic plus some other slightly less expensive sub. Q15b is on a whole different level of everything else I have tested and heard ever. If you close your eyes you will not believe that you have a sub in the living room for the last so sonically at one with my Q3. It was easy to get the integrated audio system, user interface DSP is extremely good in my opinion.
Espen
Hi
It was a much larger soundstage in both width to height, seemed like I had a much "larger" systemThe bass is clearly tighter and with more punch one in the second sub I had. There is a huge amount of effort into the sub. I have never had such a detailed bass before ever in my system. Tried crossover a number higher than 60 Hz .but then I felt that it took too much of my Q3 up the registry .. The advantage of Q15 include all setting possibilities that dsp. I use L-R 24 db with a fast roll off.
Comparison with others I have heard to tested then Q15 better in every way!!
Espen
