High gain monoblock
edorr
May 10, 2010
3,133
16
36
Smyrna, GA
I am having gain limitations problems in my MCH system, due to low sensitivity center channel (lowest gain channel is effectively bottleneck for the system). I am looking at inserting a high gain monoblock on the center. Is anyone aware of monoblocks (preferably class D with high gain (32dB and up). I know the channel island amps have high gain. Any other contenders?
I know its not Class D, but the Gryphon amps have high gain...my Gryphon Colosseum (which also comes in monos) is 31.5db in gain.
The hypex ncore1200 are 28db gain which is pretty highish. They sound killer too.
Most amps are in that range. I really need to squeeze out those extra few dBs. The channel Island D-500 comes in 32dB and 38dB version and this seems to be the ticket. It also uses the hypex module, but not the ncore.
A lot of higher-power and/or pro amps have gain in that range. For instance, the Crown XTi 2000 has ~33 dB gain, the 4000 about 34 dB, the 6000 about 37 dB.
A quick survey of various audio amplifiers (ARC, Bryston, Emotiva, Krell, Outlaw, etc.) yields 26 - 29 dB or so.
You could add a line-level gain stage if power is adequate and you just need more gain.
Goldmund Job 225 has 35dB. Not a monoblock, I know, but you can only use one channel or bi-amp your center speaker.
A customer traded in a pair of ASL Hurricanes a while ago. If memory serves they only need 0.5 V in for full output, with 50 dB of gain, I believe, which is extraordinarily high.
Thanks! This may just be my best option. Come to think of it, buying a stereo amp and using one channel may be better economics than breaking up a pair of monoblocks, which is always hard to resell.
35dB gain would do it for me.
Just read up a bit on the "job". This is definitely the ticket for me once I have the new passive center channel.
from everything I have read...great call.
