I have not heard recent ML's to speak of and generally shy away from sound comparisons -- old ears, lack of recent knowledge, and a combination of engineering skepticism and Missouri "show me" mule-headedness gets me in trouble every time I voice an opinion about the sound of anything.
What I do know is some years ago ML bass had serious flaws, IMO and that of many others. Measurements showed some significant concerns in alignment of woofers to panels. They went through a pretty major redesign that resulted in much better LF response and blending with the panels. What little listening I have done in the past few years showed much better bass than perhaps 10 - 15 years ago.
I went with servo-controlled subs decades ago, beginning with my own design (Velodyne, AudioPro were new and too expensive for a college boy, and I didn;t care for their approach so went a slightly different way in my servo implementation). The listening and measurements back then proved to me and my friends that a big part of "muddy" bass was due to ringing of the subs, nothing to do with "speed" of a subwoofer (a curious concept). A good passive design with a good amp was just as good, but the overall performance for a servo sub a fraction of the cost was usually much better. All this to help explain why the active design might be better. Another is the ability to provide much higher crossover slopes, much finer control of crossover parameters like gain and phase, and tight coupling of the amp to driver. Without a passive crossover between amp and driver cone control is much improved.
All IMO/IME! - Don
Exactly Llyod,
I have a friend who was an avid Martin Logan fan for almost solid three decades who finally took a different route for same reasons you mentioned - despite their renowned strengths.. ultimately do lack that last vestige of solidity, scale and dynamics. He last had the CLX + Descent subs/pr which I knew he did put his best effort to make it work. Here's a fuzzy/dark mobile shot I took during one of our listening session few years back..
*Amps he tried/owned included Golmund, Balabo, Technical Brain, FMA, Jadis, Wavac, Kondo plus few more I may have missed.
Not met him since, hearsay he's currently running top line Cessaro Horns+its dedicated subs (close to a Mill$ retail I was told, not sure which model), driven by flagship SET Kondos (amps+pre).. Totally different direction, so probably taste and preference do take a shift with age!
very interesting...thanks for that. In some respects, the horns may not be such a different direction, but an evolution? I am told that horns have alacrity and instant stop/start when done right...but the really big horns also have body when amp'd right. I have little experience with horns having heard 2 Cessaros only (Beta plus sub) and the bigger Liszts more recently.
Disclaimer: I am not a speaker designer.
Horns (compression drivers) have much smaller driving area and generally much higher B-E fields. They are generally much lower in distortion and higher in efficiency than conventional drivers. One of the tricks with horns is to get flat frequency response over a reasonable area given how the horn affects their radiation pattern. Planer speakers, dynamic (Magnepan) or electrostatic (ML), are at the opposite extreme -- very large area, pretty inefficient, although they also have very low distortion. Conventional drivers fall in between with a range of efficiency usually better than planers but not as good as horns, and moderate distortion not as good as horns or planers. However, when large excursion is required, planers lose on both efficiency and distortion, thus their poor rep for high dynamic range (undeserved in many if not most cases; "limited" compared to some speakers does not mean "low" dynamic range). Within their limits, horns can and do deliver very high SPL. Paul Klipsch was no dummy even if he was a bit cantankerous at times.
Back on topic: I am not sure I have heard the Summit X. How do they compare to the Montis? And, has anyone compared them to say Sanders?
