Pass Labs .8 Series!
I am not sure if power consumption on the XA60.8's makes sense but on the Pass website, here is what they state for the specs:
XA60.8 / Specifications
Power Output /ch (8 ohm) 60
Maximum Output (Amps) 20
Leaves Class A @ pk Watts 120
Power Consumption (W) 200
Number of Chassis1
Number of Chassis1
Hi Joe,
The Pass Labs website needs an update. The specs you are quoting that are on the XA-60.8 webpage are the original design specs that were written before the amps were actually built. The revised specs based on actual measurements of the amps after they were built are on a pdf file under "Additional Information" and "Spec Sheet". I got this information from a telephone call to Pass Labs. This pdf file lists the revised specs for all the Point 8 series amps.
Here's the link:
https://passlabs.com/images/uploads/manual/Point8_specs.pdf
Best,
Ken
Hi Joe,
Here's the link:
Best,
Ken
For comparison to the XA.5 series here is the link:
https://passlabs.com/images/uploads/manual/xa.5_specs.pdf
Hi Don,
Thanks for posting! This will make the comparison much easier. I upgraded to the XA-100.8's from the XA-100.5's two weeks ago. I couldn't be happier with the results and they're not even fully broken in yet. This hasn't changed my opinion of the XA-100.5's though, they are beautiful sounding amps too. Nelson is a genius.
Best,
Ken
Was reading a thread over at A-gon and found something interesting. Don't know if this guy is blowing smoke or what but he posted this:
I spoke to Nelson yesterday, via email, and asked him the very same question. He said he was not surprised that my speakers were a good match, as the M2 was voiced using the 15" version of Tannoy HPD speakers, mine being 12"
He also, admirably, stated unfortunately, that sound quality does not ascend commensurate with price.
I appreciate his honesty, and our exchange made me feel more 'grounded', if you will.
Hi Don,
Best,
Ken
Congrats, Ken!
Of course it doesn't. An $80,000 amplifier will probably sound better than a $2,000 one, but it won't sound 40x better.
Congrats, Ken!
Thanks MadFloyd. You have a terrific system from top to bottom! How are you liking your XA-160.8's?
Best,
Ken
Best,
Ken
Thanks, Ken, I'm enjoying them immensely!
Smokin' system Madfloyd!
When I first saw the .8's, I thought man do I ever prefer the look of the .5's. Not so much anymore, The .8's have grown on me and look fantastic. All need to do now is have a chance to listen, bet they sound wonderful. Nelson is the king of class A.
Thanks, Mark. They're currently driving S5's and not having to work very hard. Now I just need bigger Magicos!
Which model you have in mind?
I know where you can get a pair of M Projects!!!!
I want something a tad bigger than the S5s, but the Q series doesn't quite appeal to me. I don't know anything about the M series since Magico is so secretive about it.
MadFloyd,
Heard a Q7? The only unappealing thing about it is the price, IMHO :)
If you dig the S5 sound, you might want to look at the YG Hailey as well. I thought it was sort of a mix of the S5 and the Q3, in a small-ish cabinet.
alexandre
I have the Pass XA 30.8 which is an upgrade from the XA 30.5. I run the amp with Avantgarde horns (with a new pair of Trio's on the way to test soon in my house).
I feel the 30.8 is just slightly better but very similar in character to the 30.5. Both work great with horns with excellent bass response compared to tube amps and lower wattage amps.
Some general points
-The 30.8 will NOT fit on a standard rack which I learned to my dismay. (the point 8 series in general will not fit)
-both are very hot so be prepared to keep them ventilated properly.
-use the 12v trigger since they will consume some serious power otherwise.
-the Pass Class A amps have VERY low noise floor which is nice because many amps will have an audible hum or hiss with horn high efficiency speakers.
-the sound quality of both the old and new model are basically excellent without having to wax poetic about the various characteristics.
-the sound very high quality without me wanting for anything when paired with Avantgarde Duo Omega speakers and I will have the opportunity in a few weeks to fire up the Avantgarde Trio's with the same amp and see how things go.
