Gentlemen,
Are there sonic downsides to EQ'ing the bass? Does one lose signal purity when EQ'ing the bass frequencies? Does the life get sucked out of the music.
Feel free to argue, just please answer my question!
It must be used in moderation and preferably with other things like room treatment and careful subwoofer placement.
Gentlemen,
EQ should only be used to attenuate frequencies. Also, I've found better results using an analog EQ in the chain, such as in the tape loop of your pre. And like was said above, that it doesn't interfere with your main crossover units.
And forget graphic EQ's, use only a Parametric EQ. There you can change freq. and Q
Caesar,
Why don't you simply try some EQ and let us know what you think? You have a computer and a DAC, right?
There are many flavors available to demo and they are all free to try. You might enjoy that more than watching others fuss and fight over this stuff. That is, if you are serious about getting better bass.
Hi Bruce,
Why should it matter if it's analog or digital? we are talking very low registers. Can one actually hear the difference here, or are we just "playing it safe"?
I concur via experience. I feel that this is the biggest disadvantage. This can be a severe disadvantage....The biggest downsides to EQ'ing the bass that immediately come to mind are:
...<snip>...EQ can be used to significantly increase the power at "null" frequencies, reducing system (amplifier and speaker driver) headroom...<snip>
