I don't know about the triton...but the Typhon will definitely be on my play list after RTR and main Preamp upgrade coming soon.
4 days ago, I did what many might consider unthinkable. I unplugged my Typhon from my Triton and put in the circuit that powers the back-end which includes my Spectral 260 and 2 JL F 113's. While there was a huge impact of both unplugging it from the front-end and plugging it into the back end, not having it in either was intolerable. The Typhon's presence in the back end is quite different compared to it's front end presence.
While I would prefer one in both the front and back end's, I must say that I think given only one Typhon, I prefer it in the back-end because I like what it does to the amp and the subs, which is substantial. Also the Triton has 3 smaller NIC's which are helping the front-end and thus making the absence less of an issue than its back-end influence. Regardless, it is an amazing product.
Hi Mobiusman, please describe the audible differences between applying Typhon to the Triton for your front end, versus plugging it directly into the AC circuit to serve your amp.
Much appreciated, Guido
What power cord do they include now? It's called the "Typhon umbilical"? What does it look like?
The Typhon umbilical is labeled "Typhon AHC" on a grey-colored wrap. Thickness appears the same as the Anaconda. Approx 33" end-to-end, roughly 31" of useable length. I'm told it is specific to the Typhon and a short length is critical to the Typhon's performance.
My understanding is that the umbilical is a Typhon specific Alpha HC.
John
Correct. I just added a Typhon to my Triton about a month ago, and that is what is now shipped. Before you had a choice of umbilical types, but now it is just the Alpha HC.
