Yes, I have confirmed this with Andy Payor myself when I spoke with him.
I wonder what the price differance is. I also wonder what soundwise compromise is involved.
Lloyd, do you know if Rockport still will make the passive Arrakis?
Which output on the Arbiter do you use with Magico Q7, 40 or 1000?
I've tried both. Any recomendations?
Which one was your favorite of the two?
The 40 output low feedback of 0,2 ohm should sound better, because it control the drivers voice-coils back-emf better.
I prefer the high damping factot of 1000. It sounds like amplifiers have better control. It gives a wider and deeper soundstage with better image focus. The micro dynamics is also better.
I assume you meant that 1000 damping factor output over the 40 damping factor output because higher damping factor gives better control of the speaker drivers?
High damping factor has nothing to do with the drivers voice-coils movement. If they moves a signal goes from the speaker to the amp output stage, and amps with high feedback/damping factor have problems with it, the signal goes then to the amps input stage - the amps tries to control it, but the result is compressed sound as the amps loose the control of the speaker.
Back-emf stands for electro-motive-force.
A different name is back-emv.
Motion-induced voltage produced by the movement of the voice coil of a loudspeaker in its magnetic field.
Ok, but are there any application where the higher damping factor would be preferable?
Hi, Lloyd.
Actually I think a pair of great subwoofers like Magico Q-Sub18, Wilson Audio Thor's Hammer, JL Audio Gotham, Burmester S8 etc with a pair of Altair 2 might have some benefits compared to the Arrakis 2 in terms of bass and scale, which is closely related. This is because it gives you the freedom to place the speakers where they sound best well into the room to avoid early reflections and create the best soundststaging while you can place the subwoofers near the room boundaries where they give best bass response and scale. This setup might help cancel out some of the bass standing waves in your room...
...However to create that sense of power and energy, I think its more a combination of midbass/lower midrange and amplifier. I had that with my Audio Physic Cerubin/Krell MRA and lost it with the Magico Q7/Dynaudio Arbiter. The Cerubin has 8x 10 inch bass drivers in each speaker and a 6 inch midrange but crossed the bass drivers over at 250Hz while the Magico has 2x 12 inch bass drivers, a 10 inch midbass and a smaller midrange but the bass drivers are crossed over much lower. So they don't contribute to the midbass or midrange. I think this increased driver area in the midbass/lower midrange pluss a more powerful amplifier created this sence of power and energy - or what you call scale. In this area I think the dual midbass and dual midrange drivers of the Arrakis 2 can't be matched by Altair 2 and subwoofers.
I guess to have it all Arrakis 2 and subwoofers is the way to go.
Hi, Lloyd.
The drawback is that integrating a pair of subwoofers with a pair of fullrange seperate speakers is very difficult.
But I am not sure what you call scale is similar to what I mean with scale. Scale to me is soundstaging - depth, width, image size etc.
Hi Roy,
I have been re-reading your post which makes a lot of sense to me. The question I think (for me) which is relevant is: which of the following creates more of the power which you describe in the mid-bass/midrange region:
- Altair plus dual subs with dual-mono or monoblock
- Arrakis (but passive with only stereo or single monoblock
The reason I ask is because even in my dream system...I am not sure I want to have the cost, size, room, setup and maintenance of 4 ICs from preamp to Active Crossover, 4 ICs to 4 monoblocks and 2 sets of cables running to the Arrakis.
Which means the above 2 options are more likely a comparison even in a dream system. A well setup/ideally setup of Altair 2 plus dual subs...or perhaps a competently (but not all-out) setup with Arrakis passive.
Why not going to passive Arrakis with subs?
I just want to pop in and tell you guys that I am back after a short breather and a good hard think. I hope to be able to contribute positively at the forum in the future.
