For any product that changes room acoustics, the only way to validate or invalidate is by performing measurement tests, that's fairly easy to do with proper measurement equipment. If there is a big enough difference that will show up in a room measurement. Please, to satisfy the skeptics, show before and after room measurements.
As I won these, I have no financial stake in the addition of HFTs to my room. I also lack the necessary equipment to perform any measurements that would depict a change due to their addition.Perhaps another WBF member who owns the requisite measurement tools and owns some HFTs would be able to take up this project.
Lee
Lee
How are you able to use the Dirac software without taking any measurements?
Amazingly effective.
No darn reason why they work...
Ppseudo science or pure chance. I don't understand it.
I don't know how such a small device such as this would make any large change in the sonics within a room. It would be easier to buy into it if this device was larger in size, I would tend to believe that a little more than something the size of the end of a pinky finger. Seriously, I don't know how the audio waves moving in a room would be affected that much to be audible by a teeny tiny device such as this. And what's inside the box they plug in? Something that gives off some change in the negative or positive ions in the room?
I think this product should have been posted on April 1st. It would have had a far greater impact. If nothing else, I got a good laugh from this exercise.
I think with your vast knowledge and listening skills, you should contact Synergistic Research and offer to take some measurements in your listening room for them.
I don't have room acoustic measurement tools at my disposal. If I did, I would have already done so and posted before and after.
Then stop posting your requests for measurements from WBF members and get some measurement tools or contact the manufacturers and ask them for measurements.
If you want to prove your points you need to invest some of your own time and resources.
I'm requesting the measurements to be done by the mfg of the product and then validated by the professional reviewers, that for all intended purposes SHOULD have the test equipment, know how to use it and interpret the results. if another member has such a product and also has test equipment, etc., that would be great as well. But the ownership of PROVING a product is originally placed on the MFG to show test measurements, then it would be GREAT if professional reviewers or certified Acoustic Engineers, in this case to repeat the tests and to validate them. That's part of how things SHOULD be done for products. It's provides more credibility.
If there are any certified acoustic engineers, which I know there are on this site, they can certainly chime and in and offer their expertise since this is a room treatment product, which is what an Acoustic Engineer studies and is familiar with the testing procedures.
I'm with jap. This is the nth thread that you walk in and demand measurements, first from the poster, then you back away and claim that manufacturers and reviews must do it.
Well, if measurements are so important to you, there are leads elsewhere on this forum to about $350 of product (that can be purchased off Amazon) that will help you measure your room. If you don't have $350 to invest in something that you hold so dear (measurements), then I don't know what to think...
alexandre
