AudioArts has both the K10 and K15 in NYC...apparently the K15 is just better....(which I love my K10 so much is just hard to imagine "more")
Hi jfrech , would you concur that the K10 has a tube like presentation , as has been reported .
Enticing description...would love to hear it. Jazzhead...have you read Martin Collom's review of it?Absolutely...the K10 is very dimensional, musical...has this relaxed quality about it, never aggressive...but super fast dynamics and resolution that can startle you. It seems to remove the gap on tubes/ss. Over the last 15 years I've owned a BAT VK50/50se/51se then a Nagra PLL and now the Koda k10...The BAT and Nagra were tubes...the Koda K10 is in different league than those very good preamps...
When I was evaluating the Nagra PLL, I choose it over a BAT Rex, Ayre KXR and Aesthetix Callisto Eclipse in head to head same system comparisons. Now the Nagra isn't better in every way than those three...but did have the best balance of virtues. So like on scale of 1-10 the BAT Rex would score 10 of a few of my items then a few 7 and 8's. Ditto the others. The Nagra kept coming up 9's on most everything.
The Koda comes up all 10's with a few 11's. Just doesn't seem to have a weakness...just strengths.
When I was evaluating the Nagra PLL, I choose it over a BAT Rex, Ayre KXR and Aesthetix Callisto Eclipse in head to head same system comparisons. Now the Nagra isn't better in every way than those three...but did have the best balance of virtues. So like on scale of 1-10 the BAT Rex would score 10 of a few of my items then a few 7 and 8's. Ditto the others. The Nagra kept coming up 9's on most everything.The Koda comes up all 10's with a few 11's. Just doesn't seem to have a weakness...just strengths.
I would like to specifically touch upon a few reported points 1) it's immunity to aftermarket PC's and isolation , due a well sorted out PSU and structural built 2) a relatively low voltage gain of 6dB , means that it will not pair well with a similarly low gain power amp , have you tried it any other amps other than your Ayre. 3) The need to advance the volume knob above the 12'o clock to obtain a satisfactory SPL , this being a throw back to it's unique fully analogue mechanical solution .
How does the K-10 do on top octave "air" which is a speciality with tube circuits . Look forward to your thoughts , thanks for taking the time to provide requested feed-back ..
I haven't heard vast numbers of SOTA tube and SS preamps, but I suggest it must really be up there, and really seems to occupy that rare strata, a device which sounds neither like tube or transistor, but something better.
My other main conclusion is that i TOTALLY DISAGREE that it's immune to power cords/isolation etc. The change to the Sablon PC and Symposium isolation have radically changed it's nature in my opinion, from interesting but flawed, to ground breaking.
I am really happy you got to hear the K10 at it's best...And I agree...like everything good isolation and good power only help it...
Trust me, when it leaves your system...it'll be tough to be with out....that's what sold me...all the little things it excels at...just saying![]()
Instinctively, I think its the one preamp I would consider seriously besides my GAT. I have no desire to switch, and I am not going to inconvenience the Distributor with an audition, as I definitely would not be serious about it. Nevertheless, from all the people I have spoken to who have heard it and/or own it, and based on Robert's lineage from Kondo, this piece is most intriguing.No boys, it'll deffo be going. I'm sanguine about the high end to not be too regretful if I miss out for a while. I've been wanting to make a comparison to my Hovland for a while, as the only component in my system that's been in longer than 2 years (7 years in the case of the HP200), but I was actually only going to consider another tube pre. I'm astonished at the (almost) non existent noise floor, and the balance of power and sweetness which seems to transcend the tubes v transistor divide.
K10 review has just appeared in high Fidelity. It is in Polish now (you can try google translate) but it will probably end up on their english version soon.
http://www.highfidelity.pl/@main-2060&lang=
Just taken the K10 out of my system ahead of it going back to the distributor tmrw. Feel I've got a handle on it, esp. how it morphed when switching power cords/isolation. The only "issue" I have w/it is a tad lack of drive w/more distorted music like metal/grunge/rap etc. This is only a minor criticism, but I wouldn't recommend it as a first choice to a headbanger/rap fan. This slight caveat aside, the opening up of the higher frequencies going to Sablon Quantum Gran Corona power cord/Symposium Rollerblocks has completed the spell - what a performer: an amazing stability of soundstage based on ultra low noise/overengineered power supply, really extended supple bass, transparent mids, and (now) fully extended highs. What is most impressive is the truly holistic quality, non highlighting of any one part of the presentation over any other - no spotlighting a la: Krell iron grip, Soulution ultra neutrality/transparency, BAT warmth etc. As a result, you can listen "thru" the mix, or just melt into the music. And like all great components, it gives you that amazing "remix" phenomenon - listening to a really familiar piece of music sounds totally fresh w/strands and themes totally new being revealed, but comfortable because the piece overeall remains totally familiar but enhanced - like a new music library/impvd existing one, all at the same time.
