So I tried this today...
Interesting. So with my Typhon plugged into the Triton...SPL readings on my iPhone are 78-79-80 (kept bouncing around a bit)...pull the plug and it's 76-78-79...definitely a db lower...
So here is my dilemma and confusion with the 2 experiments I ran. I had a talk this morning with Marty regarding the results and here is our concern........
On the first day when Marty was here our experiment was different than what I did yesterday
We listened to Silent Night from Cantate Domino at preamp level 10 with the Typhons plugged in. Unplugging the Typhons resulted in a subjective decrease in SPL such that when we upped the volume on the preamps to match the first listening level we had the preamp at listening level 12-13 (2-3 positions higher on the gain control) which translates to a 4Db difference
Yet when I did a slightly different experiment yesterday by measuring the SPL at listening level 10 with the Typhons plugged in, I got 72 Db
Then when I unplugged the Typhons and remeasured the SPL at listening level 10 I got 71 Db
So here is the question that Marty and I cannot explain....
"how does an effective difference of only 1 Db objectively result in a subjective difference of 4 Db ? This is what eludes us in trying to explain why we had a subjective 4 Db change. Thoughts anyone![]()
The db measurements are of the total sound the system is producing...including system noise, distortion, etc. Your changing the volume was a reflection of your listening solely to the musical signal, words, etc. perhaps to get the same level of clarity of words, etc you needed to turn the volume up louder...or perhaps with the typhoon, the delta between noise and music signal was such that you could hear the same music at 4db lower absolute volume relative to without typhoon.
Did it remove 3db of grunge?I wish I could explain it Lloyd
IOW a 1 Db change with the Typhons plugged in resulted in a 4 Db subjective difference in SPL.What's going on that gives us that perception
Steve,
As you know I have doubts about the accuracy of you SPL measurements, and will not comment on the 1 dB difference, but I can easily accept that your subjective perception of sound level depends on the quality of the sound reproduction and your enjoyment of the system. If the Typhon reduces the subjective noise of the system - the famous black background, you feel a larger dynamic range. Perhaps in order to restore it you need a louder level when you play without the Typhon. Just digressing about matters I know little about ...
I thought my results were quite reproducible
So maybe instead of listening and measuring speaker output, maybe you should measure amplifier output via a voltage meter for better accuracy.
My thoughts exactly. Using an iDevice or Radio Shack SPL meter to consistently detect a 1 dB difference in a listening room seems pretty unscientific.So maybe instead of listening and measuring speaker output, maybe you should measure amplifier output via a voltage meter for better accuracy.
