Preferred aes/ebu 110 ohm digital cable you have tried
audioblazer
766
208
1,605
Malaysia
Currently using Transparent Reference digital cable between my Aurender S10 and MSB diamond IV plus with Diamond Power supply . Looking for option to upgrade my digital cable . I know the best is subjective . Hence my thread titled : Preferred digital cable ......... Heard good things about Transparent Reference XL AES/EBU digital cable raved by Jacob Heilbrunn . Any feedback is much appreciated
Andre Marc
3,970
7
San Diego
www.avrev.com
The DH Labs D-110 AES/EBU is easily the best I have tried.
Assuming you don't have low price aversion, it is a great sounding cable.
http://www.silversonic.com/docs/products/D110.html
Ronm1
1,745
4
wtOMitMutb NH
Revelation Audio Labs
I've used their AES/EBU and I2S Neutrix silver's for years. Though I haven't compared recently they were easily the best at the time.
audioblazer
766
208
1,605
Malaysia
Andre, that seems like a good option at usd99.
Bruce , 1 of my local guy reviewed it very favourable
Andre Marc
3,970
7
San Diego
www.avrev.com
Disclaimer...I have NO financial affiliation with DH Labs..!!!! (Thank god that thread evaporated!)
I have a full suite of their digital cables and I find them to be superb.
garylkoh
Sep 6, 2010
5,599
225
1,190
Seattle, WA
www.genesisloudspeakers.com
I'll throw my hat in with Bruce and Andre and recommend both the Mogami and the DH Labs, and add one more - the Apogee Wide Eye. The Mogami Gold is the most neutral, the DH Labs a bit warmer (which is a paradox since the Mogami is copper and the DH Labs silver), but overall I usually gravitate towards the Apogee.
I have no financial affiliation with either Apogee, DHLabs or Mogami. I paid full retail for all these cables plus shipping.
I also have a few audiophile brands I will not name that do not sound as good as the three above and are very much more expensive, but I didn't pay for those.
These impressions were formed when the source was primarily red-book though. I haven't had to use these cables since USB DACs became the norm in my listening.
Andre Marc
3,970
7
San Diego
www.avrev.com
Gary, the DH Labs features microns of silver coating, however I believe the conductors are copper.
dallasjustice
2,067
8
Dallas, Texas
MIT Oracle Ma-x is the best I've tried. I think there's a pad in the box that helps to eliminate reflections. Order the longest version you can, if possible. Mine are 2m.
jfrech
2,157
753
1,160
Austin
I'd add the Purist Audio Designs digital cables to your list to consider. I have not tried the AES/EBU versions but do use 2 BNC/BNC Proteus Provectus Praesto cables...I will likely try the Transparent Ref XL's next...might be a few months...
If you like your Transparent today...their upgrade program is hard to skip out on...you should get $1256 off the Ref XL...(assuming you have 1 meter)
4,704
I'll throw my hat in with Bruce and Andre and recommend both the Mogami and the DH Labs, and add one more - the Apogee Wide Eye. The Mogami Gold is the most neutral, the DH Labs a bit warmer (which is a paradox since the Mogami is copper and the DH Labs silver), but overall I usually gravitate towards the Apogee. (...)
Gary,
The Mogami Gold AES/EBU is made with the W2791 cable?
IMHO, it is not possible to extrapolate the sound of cables from analog to digital. One of the warmest and full sounding AES/EBU cables I have used was the analog Kimber KS1136. I found it because I did not have a proper digital cable at that occasion ...
Speedskater
941
15
368
Cleveland Ohio
It takes a lot of big expensive machines and a expert quality control department to make good modern cables. So I'll stick with major brands like Belden and Mogami.
garylkoh
Sep 6, 2010
5,599
225
1,190
Seattle, WA
Gary,
No. W2791 is an analog balanced cable. The AES/EBU Gold is W3080. I've also tried building my own using the various available Mogami AES/EBU formulations, and the one I most prefer is the W3228. However, as far as I can tell, they do not sell it as a made-up cable. Dallasjustice's comment should also be taken to heart. I find that all these AES/EBU cables perform best when they are longer than 2m.
I found the same. Some analog cables will work as an AES/EBU cable, but they will 'tailor' the sound. My comment was just to inform readers that the DH Labs AES/EBU had a warm sound. Everytime I recommend DH Labs as an economic solution, my customers ask me "Isn't silver supposed to be bright?"
audioblazer
766
208
1,605
Malaysia
Jfrech, yes I m using a Transparent Reference digital now
nirodha
695
308
1,625
Got the Oracle MA-X as well. Awesome! MIT is so easy...the more you pay, the better it gets ;)
audioblazer
766
208
1,605
Malaysia
I suppose MIT is good but don't like the inconvenience of the network . It can be a pain positioning it on the rack or left it dangling which is not a good idea. Sold my IC because of this issue. Anyway thanks
Scott W
165
1,600
Texas
www.suprahifi.com
Audioblazer,
The MIT Oracle MA-X digital has a much, much smaller and lighter network box then the Oracle interconnects and hangs just fine with no problems at all.
Scott
4,704
I'm using the Transparent Reference XL and think its superb.
Are you using the AES/EBU or S/PDIF? Still with the Briscati M1?
