Site Founder, Site Co-Owner, Administrator
It is a short power cord however it is the actual length of the umbilical that makes the Typhon effective
FWIW the umbilical is made differently if the units are to be stacked on one another vs side by side
Yes
Also it should be bought with the same cable as that used in the Triton.
IOW I bought an Anaconda PC to be used from the Triton to the wall and an Anaconda umbilical for best results as stated in the brief instructions that came with
Nice. Are you changing all power cables to Shunyata?
I have remained tight lipped so far on what I have been hearing but so far I have to keep pinching myself to be certain that I am still listening to my system rather than a different one as the sound has changed so dramatically. I now have just over 100 hours on the units and I have them left on as Grant recommended for break in. He suggested merely leaving on the front end components going into the Triton but not running signal through it, IOW he said that the components just need to be turned on
This is of course all very intriguing, and I will have to try this myself at some point. Can you explain precisely what Shunyata components (Triton / Thypon) you are using in what configuration on which pieces of your gear (poweramps, front end components).
Hi, I'll chime in here also. My front end is plugged into my Triton/Typhon (dCS Scarlatti trans, dac and clock along with my preamp and turntable motor controller). My phono stage is on a battery currently. I have tried my amps...but prefer them direct to the wall (with shunyata cords and ac outlets)
So far all I have done is buy a Triton/Typhon/Anaconda PC and an Anaconda umbilical which plugs into the Triton
Presently plugged into the Triton other than the Typhon is my Studer A810, my Doshi tape preamp, my Playback Designs MPS-5 and left and right channels of my Lamm LL1 Signature preamp
The Triton is not recommended for power amps. I don't know how else to say this and make it understood as you also are commenting on the Triton for power amps.
But Frank is reporting great results doing just that ........
.....Just plugged the XA100.5s into the Triton.
To say there was a change would be a gross understatement! Bass solidified, a kind of grunge I had taken note of was gone. Everything was smoother, cleaner, more liquid. The soundstage improvement is amazing, both in depth and width as well as definition of players on the stage. These were not slight improvements. It sounded like I had inserted a different preamp and amplifiers into the system. For my own sanity I plugged the amps back directly to the wall to make sure I wasn't hallucinating. I wasn't.
well why don't you ask Frank how it sounds with only a pair of Typhons in the AC outlets for the amps
To Triton or not to Triton (on poweramps), that is the question! Frank - say the word.
