This is for those Allnic owners that are handy with a soldering iron or know someone that is. I've owned the H3000 for about a year before I decided to try this and I'm glad I did. I bought some 68k naked z-foil resistors. I bypassed the input resistor switch and soldered them straight to the input block. This of course will mean you can not change the resistance without soldering in a different resistor but I found no need to do so in my setup. I also have a friend that tried it on his unit with good results as well. On the Allnic you can still adjust the loading somewhat by adjusting the step up transformers.
This results in a sound that is more pure. It does not change the tonality that I noticed. At least in my system and that of my friends there was no down side short of less loading options.
