I thought I would start a Magico thread that would simply show images of speakers in systems and not attract much controversy.
What did the room look like before Jim Smith RoomPlay?
Perhaps I missed this but what are the amps sitting on?
Peter, I don't know if this is question is directed to me or to Stereo, but if it is, each amp is on a platform composed of the following:
1. 3" 17-ply per inch birch plywood, spec'd and finished to match wood of the Mini IIs.
2. 20" X 24" Vibraplane air-isolation platform fed my an air compressor in basement.
3. 136 lb. 20" X 24" X 1" steel ballast plate to pre-load the Vibraplane near its optimal design load for max. isolation performance.
I was actually quite surprise at how this platform improved the performance of these SS amplifiers.
Interesting.
I would have thought to try Vibraplane -> ballast -> birch ply -> Amp. Seems like that may have yielded a bit more isolation.
Did you try that configuration? If so, what were the results compared to the configuration you currently have?
Dre
