About the "frugal" side of "expensive" sub equation: http://thehornshoppeforum.com/index.php?topic=406.0
One sub is almost impossible to integrate. Two with a little practice and an RTA is a snap. I skipped 3,4,5 and 6. Most I've done in one room at one time is 7. The only thing difficult was running around.
He told us that if one feels he needs more bass extension or output, he should just buy a bigger Magico speaker.
I'm in Frantz's camp. There are very few rooms where multiples of subs don't outperform a single sub. I would much rather use multiples of less costly subs (Seaton, JL, IB, etc) than one of these monsters at a whole lot less money and much better FR.
Who said you can't use two ? Or 3, 4 or 5 ?
Most of US would probably go for cheaper designs, but that is not the point. I belive Alon Wolf wanted to create a non plus ultra design, for audiofiles with rooms big enough and pockets deep enough, not to care about the cost. I bet he will sell more than a few.
Wilson has been selling their Thor designs for a quite a few years now (I belive they are also around $30k) and those don't even have a built in amp. Yet - noone complains or questions those.
“136dB of sound pressure level with less than 1% total harmonic distortion at 20Hz” sounds almost impossible to me. I would like to see some measurements that would back that up (unless it is a typo).
One thing is clear though - even with much smaller, 'real life' SPLs, this subwoofer will give you much less THD than your main speakers - whatever they are.
To give you a better idea - Wilson Maxx 3 already has 3% THD @ 20Hz at 106 dB - and that is already considered a stellar performance.
I have two F113. Probably the best "cheap" sub on the market. They are good enough for home theater, but yes, they are too weak to pair with my Q1. I tried and did lose transparency.For sure.... I'd certainly not call the Fathom F113's or Gotham's weak or lacking in any way.
Elberoth
Respect your opinion. I do however believe that the point is not about how expensive a product is but how well it performs. If the goal is prestige or status , I'll bow out of the discussion. If it is getting the best performance for a given amount of money expenditure, it is to be proven that these 30K subs are worth their weight in ...well ... Aluminum ... I contend that lesser priced designs could do as well .. I need to be shown that my reasoning/POV is wrong, in the meantime, this looks to me like one more expensive product aimed at those with the wherewithal to spend a lot.
You may have a noticed I am a Magico fan. I do however practice this perspective for any product: It must beats the competition in performance metrics not those of exclusivity, prestige or status. Those may make someone happy but do not help reproduce music any better, which is what matters to me.
About subs ...
The best bass possible in most rooms is achieved with subs ... Not an opinion a fact. that notion of subs never integrating with mains is false. Reproduction in most rooms benefits from adding subs. regardless of bass capabilities of the mains ( I know I am repeating) . Facts not opinions. Subs to mains integration is all about crossover points and bandwidth and phase... IOW you don't want your subs messing up up in frequency with your mains. You may want to keep up also with phase. All this is achieved by not necessarily expensive means, the better of these means ... the hated, dreaded, DRC used in the bass only. One additional myth that needs to be struck down: That of Class D amplifiers not being to the task.. In the bass they are most needed. they are efficient and provide extreme power at low cost, Bass for the most part requires power... A generalization true but one with substance, you need power to move a lot of air in the most linear fashion and for that CLass D is the designer's best bet. One can claim that Class A is the best for the job and all that; the point remains that a cheap , inexpensive Pro amp can do as well as other amp in the bass ... in the whole spectrum? A very different case, in the bass I repeat... in bass Class D are likely the best one can do. As usual the audiophiles will resist and then warm to it. Multi-subs are making inroad in Audiophile circles. Von Scheikert makes such a speaker system and other will follow.
Now concerning the extreme cost of the Magico speakers. Again the audiophiles mentality of more money = better sound is as usual ( and again) at play . And that will not change. Telling the buyer how expensive it is to product their ware is a good marketing strategy, similar to the one used by watchmakers... You know, great watches entirely made by hands; for the purpose of telling time these are bettered by Casio Quartz, regularly, second after second.. if it jewelry one is after then the expensively watch may look better or satisfy more... This could be the same here. I would like to see studies pointing to the fact that Aluminum is the most suitable material for subs. So far aside from Magico claims (remember , I am a fan of their speakers and would gladly acquire them) I don't see why it has to be Alu in the subs ... It makes great marketing material but the proof is in the sound. And the physics and psycho-acoustics of bass reproduction in a room show that more subs are better than one. and more translate in more linear and more extended output both in magnitude (SPL) and reach (lowest frequencies attainable), while lowering distortion. Let's suppose for the sake of Argument a person wanting to use ,say, 4 Magico $30,000 subs for a nice 120 K of subs... Do you really think that 16 (!!) Paradigm sub 2 or 8 (!!) JL Audio Gotham with a serious parametric EQ (Digital preferred) wouldn't do a better job if the goal is extension, integration with the mains and low THD? Granted, the logistics then wouldn't be simple but if you have that much money to spend on subs ... With the same mains, I believe one can achieve the same or even better results with 8 Seaton Submersive. at 1/5 of that price ... thus money left for a sublime room treatment and construction...
Magico makes them and they will sell a few to high heeled , extremely rich individuals .. And the tide will recede and they will fall by the wayside. The Krell was likely a great sub , one has to wonder why it didn't survive all that well.. Could it be that it was regularly bettered by more pedestrian-priced designs? Did hear the Wilson XS and for all its girth and price, The Gotham surpassed it .. Heard them in same room and same system ... And in that particular system, integration with stellar (and pricey) mains wasn't a problem ... Ask the owners if you will , he downsized to smaller JL Audio subs with the same mains and electronics and seem to be happier (Room has something too, to do with the elevated sense of happiness, methinks)
The Qsub is a better sub not because it is more expensive. It is more expensive because it is better and costs more to build.
I can understand that people having a Magico based HT want to have a sub at the same level of quality. I would buy one or two for my HT if they wouldn't be so heavy... too heavy for my floating floor (and I have now 2 fathom F113 which are good but still the weakest element in overall system)
About subs ...
Do you really think that 16 (!!) Paradigm sub 2 or 8 (!!) JL Audio Gotham with a serious parametric EQ (Digital preferred) wouldn't do a better job if the goal is extension, integration with the mains and low THD? (...)
What you say is very true, but then again - I'm not sure the single subwoofer configuration is actually recommended by Magico (or any installers for that matter).
I belive it will shine if the setups of those lucky few, who will be able to afford multiple of those.
Pardon me Dan but again did someone pee in your grape nuts again this morning?
I would never buy a sub for that amount of money period!!! Nor would I only buy just one sub
FWIW Dan before you open mouth and insert foot you should do your research as I own a pair of JLAudio Fathom subs.
Oh and one last thing to you Dan and also to stereo, FWIW, I owned a single Wilson XS sub which I had in my system before I heard the JL Audio Gotham at which point I sold the XS (and you all know I am a Wilson fan) and bought a pair of Gothams. I sold these when I moved and built a smaller room and now own a pair of Fathom subs
So once again Dan I suggest you wake up on the correct side of the bed because you are starting to show the Dan that we sometimes know here and often gets you into trouble
I suggest you take a deep breath and think before you post
Mahalo
