Peter-I read that article yesterday and found it quite interesting. It just reinforces what many of us know-we all don't like the same things in music reproduction.
My bigger question is what percentage of speakers being manufactured today were designed so that they will sound their best with an amplifier that conforms as strictly as possible to the power paradigm vice speakers that will sound their best when driven by voltage paradigm amplifiers?
That was the Bose philosophy and I always found it to be flawed...
in my other post, I referred to this whole issue as a variation of the old musical vs. accurate theme. When the designer's goal is to "replicate the perception of a live performance" or create musicality, or euphony, or warmth or an enveloping presence or whatever poetry of the day describes this approach to audio design, one thing is clear; the designer is endeavoring to broadly, systematically alter the art; all the art played on the system.
Although I'm sure they exist somewhere, I've personally never seen a speaker designed for constant power.
This topic comes up surprisingly often, and you will find components that adhere to this so-called "power paradigm."
But to answer your question about how many are designed for CONSTANT VOLTAGE, the answer is: almost all. The reason I know this has to do with speaker measurements and how they're done. The standard is to applied a CONSTANT 2.83V across the frequency band, and with that the speaker comes out as flat as its intended to. In other words, it's made for a constant voltage. Although I'm sure they exist somewhere, I've personally never seen a speaker designed for constant power.
I first encountered this issue with an Orpheus Labs amp I reviewed VERY long ago -- it was a solid-state "constant power" amplifier. It had a special circuit so that its power remained the same regardless of load.
Doug Schneider
www.soundstage.com
If that was indeed Bose's philosophy, its implementation (as embodied in the 901), is what was flawed.
For the right way to do it, see Floyd Toole's "Sound Reproduction: The Acoustics and Psychoacoustics of Loudspeakers and Rooms".
Yes, quite interesting; been reading it the last few years again and again... Off topic, but I find Pass having matured a lot in his designs since the Aleph days - the last Pass product line I experimented with and found it to be what a lot of people hate about solid state.
That was indeed Bose's philosophy and the entire reason he created the 901 to bring his dream to life. I would think that anytime you add something to the signal in order to change the sound, you have a high risk of having a flawed implementation. Whether it's 8 drivers firing backwards towards the wall so that most of the sound you hear is reflected or whether you add 10% THD to the signal.
i am not sure about that one. any time we even think that two channel is "supposed to or even attempt to" sound like the real event, its the first, and fundamental wrong step IMO. just as has been brought up in this thread about how the speaker attempts to control the amp, ie feedback or none in either case the speaker still controls the amp to certain extent, butr just differently, "stereo" controls the listening experience. its a totally differnt animal, and at best can hardly deal with more than three instruments playing at the same time before the IMD starts to "become" the new sound as opposed to the recorded sound. let alone, the "stereo effect".
i have never and never will expect a stereo to sound like the real thing, not in the same room. but play some simple acoustic guitar, and go down the hall to another room and yeah, you could have a hard time kmowing if its real or not.
IMO the first expectation to get over is ecpecting stereo to sound real. then, IMO, you are left with assembing a system that is accurate to the recording and adding in your own processing, or assemble as system that overall creates a sound you like, without processing. either camp, IMO works, but if you do the processing your less likely to feed the high end manufacturers sales though.
Mep,
The idea is not adding 10% of distortion to anything. As far as I understand the main idea is having the proper relative values of the different harmonics, even if this has a consequence of getting an higher value of an harmonic that does not affect sound reproduction in a nasty way.
Fransisco-It might not be the idea to add 10% THD, but it's a byproduct of the design and it exists. You say it doesn't affect sound reproduction in a nasty way, but I guess we must ask relative to what? If you mean relative to high order odd harmonics (5th, 6th, 7th, etc.) you can probably achieves some degree of consensus on that. The bottom line is that 10% THD is going to affect the sound. It may affect the sound in a way that pleases you and others (and hell, it may please me when I hear some of Ralph's amps at RMAF), but have no doubt it will affect the sound.
Mep,
I can not understand why you insist on the 10% figure. As said by Ralph the 10% is untrue - it was due to an inadequate measuring technique (these amplifiers have a DC coupled cyclotron output configuration) and an unit with faulty tubes. It can happen with the Atmasphere's - when they are faulty the tubes become open circuit and only affect reproduction reducing power - no tube big-bang!
Fransisco-Go back and read what Ralph said about the bad tubes and the way Bascom King took the measurements. I *believe* that Ralph said the reason the MA-1 didn't meet the specified power output was because of the defective tubes and the way Bascom set the variac. Ralph went on to say in another post that his newer amps have 90% less distortion than the MA-1 did which means that his current amps should measure 1% THD.
Duke-Do you know if any magazine that takes measurements has reviewed one of Ralph's amps since the MA-1 review and we can see some measurements of the new amps? I would rather we had nothing to quibble about and I'm looking forward to meeting you at RMAF. You seem like a cool dude in a loose mood.
