Duke LeJeune
Manufacturer - Illusio Audio and AudioKinesis
Just for kicks, I did a simulation of a subwoofer designed to have flat response when driven from a low output impedance. It is a Dayton RSS390HF-4 in a 5.5 cubic foot box.
That's not a woofer that I would ever use with a power paradigm amplifier.
Instead, let's look at the Faital 12FH520. This is a high efficiency 12" prosound woofer with a very good motor, smooth response to nearly 3 kHz on-axis, and inadequate bass response when driven by a voltage paradigm amp. Except for that inadequate bass response, it's a good candidate for a high performance two-way with a horn or waveguide for the top end. My modelling software assumes an amplifier with negligible output impedance, and suggested .8 cubic feet tuned to 62 Hz for a F3 of 75 Hz as being a "maximally flat" alignment. Hardly inspiring bass performance.
Here's a link to this woofer's spec sheet:
http://www.faitalpro.com/products/files/12FH520/8/12FH520_datasheet_8.pdf
I don't have the program you have, so will have to hope that you don't mind running that simulation again for this woofer. Try a six cubic foot box tuned to 35 Hz, and run it with an output impedance of 0 to 6 ohms in one ohm increments. At about 4 ohms (the output impedance of the Atma-Sphere M-60), you should see a nice flat bottom end that extends to the lower 30's.
So the Faital 12FH520, when driven by a solid state amp, is at best a midwoofer that would need help from a subwoofer, but it becomes a serious fullrange woofer when driven by one of Ralph's amps.
Do you see how approaching this woofer from the power paradigm gives us radically different results than when we approached it from the voltage paradigm? The difference came to more than one octave of bass extension. Sure we had to make the box bigger and tune it lower to take advantage of the power paradigm amp, but we still got to enjoy its dynamics and smoothness without having to buy a subwoofer.
