I doubt it would happen though. I owned the D70 MKII and I heard the REF-75. I know which one sounds better to my ears.
Truly.
All it takes is one listen with the Ref. 75 driving either the $195K or 10 K NOLA speakers!
Have any of you guys actually listened to a D70Mk2 with newer ancillary gear in the last few years? Or, are you simply relying on an audio memory that is years old. I'm going to try and source a Ref75 to put up against my D70Mk2 and play them both for all to hear. Should be an interesting AB. I think the last person to hear my D70Mk2 was Flez, maybe he could comment.
the d70 mk II was my first 'high end' tube amp, i drove maggie IIIa's fairly well with them back in the day - it was ballsy for a 60w amp. schlepp your d70 over to stereo design i can arrange to have kentron or art set up a system for a shoot out.
I listened to it with the Convergent Audio SL-1 MKII that I used to own which is the same preamp that you own (or yours may be a generation behind). The D-70MKII is a very nice sounding amplifier. It will not have the bass quality and extension of the newer ARC amps. The VT-100 MKII would smoke the D-70 and the VS115 is just in another league entirely. The REF 75 has a bigger power supply than the D-70 and it has the KT-120 tubes which I think give the best bass compared to the usual contenders (6550/KT-88).
What about midrange?
That's a great question, Keith. Since the power output of the two amps is similar and the the D70Mk2 is well known as having one of the greatest midranges, I'm thinking this is where the D70 will prevail.
I love how mep states above that the VT100Mk11 would smoke the D70Mk2.....since it wasn't "smoked" by a VT100Mk3 in an AB that our group conducted about a year ago.
Instead, the owner of the VT100Mk3 was so amazed at what the D70Mk2 could do, he sold his VT100Mk3 and bought M100's.
BTW, If you were to ask Ken Stevens which tubes he prefers...the new KT-120's or Winged C6550's...you will get an interesting answer! ( Hint, it isn't the newer tube) BUT then again, what does Ken know![]()
Like I implied in my other thread, IMHO to give an opinion on an amp that one hasn't heard in another's system and in how long, is foolhardy at best!![]()
Quick question gentlemen: How can I connect the REF 75 to my (futur) REF DAC if the balanced XLR Analog output of the REF DAC is already used to connect my balanced Headphone Amp to the REF DAC ?? I have a pair of XLR-Out missing !
I know that some people including Carl Marschiotto of Nola like the 75 better than the 150.
Probably because it's easier to keep two output tubes per channel reasonably matched and biased correctly than it is with 4 or more per channel. The REF 75 just hits a sweet spot on both power, simplicity of a single pair of output tubes per channel, and looks. It may well be one of the best looking amps that ARC has ever made. And, it will be easier to maintain the proper bias than scads of other ARC designs.
Have you heard it Mark? It appears to use less negative feedback than the 150, which may result in folks preferring it over the 150.
http://www.stereophile.com/content/audio-research-reference-75-power-amplifier-measurements
Keith,
There are so many and so large differences between the two amplifiers that I that I think we can not be sure that the sound differences are due to the small difference in negative feedback (1dB). I heard it once, but without direct comparison in my system I will not risk an opinion.
