That's false, QRD's do not need to be symmetrical.
2D panels modulated - nine asymmetrical N5 2D QRD panels with three rotated. You can shift the position of the pattern, test it out with any 2D QRD generator.
Any 2D QRD calculator?
I don't know if he started writing on the calculator independently, or if it was Terry J's thread at gearslutz that set the ball rolling. (the same Terry as in this thread - hello mate!
The picture you linked to above is a combination of different QRD's. It doesn't mean they're not symmetrical on their own. All QRD's are symmetrical around their middle point, except for the starting well. A QRD sequence is:
n^2 modulo N, where the n is the sequence step and the N is the prime number.
For the prime 5 N, the sequence is:
0^2 mod 5 = 0
1^2 mod 5 = 1
2^2 mod 5 = 4
3^2 mod 5 = 4
4^2 mod 5 = 1
The first line in the 2D QRD you posted above is the result of inserting a constant in the sequence:
(0^2 + 1) mod 5 = 1
(1^2 + 1) mod 5 = 2
(2^2 + 1) mod 5 = 0
(3^2 + 1) mod 5 = 0
(4^2 + 1) mod 5 = 2
And this 1-2-0-0-2 pattern is shifted one step to the left, giving the 2-0-0-2-1 depth sequence seen in the first row. All the rows in the 2D sequence can be decomposed in a similar pattern. The "1" is 0 depth starting well pluss 1, and the rest of the sequence is symmetrical. Ditto for any QRD sequence you can manage to procure forth. They're all symmetrical.
--- back on track:
the smaller 3x3 parts of the golden horn diffuser does not match the prime 3 QRD pattern. Neither does the overall larger pattern look like a QRD as they are strikingly symmetrical:
The picture above is from this thread at gearslutz: http://www.gearslutz.com/board/so-m.../431360-diffusor-baffles-skywalker-sound.html - which, as you can see, is where the 2D portion of the QRD calculator started.
