Doesn't it just mean that active speakers are your preference then? Why all the technical stuff to support your preference?
Yes, they are my preference. What technical stuff?
Tim
Wanna revive the wager Tim? Blind test, right up your alley.
Wether you are splitting up a large or a small signal there are passive parts involved. Active stages all have signatures. If you are talking only about efficiency, I would agree with you. If you are talking about levels of fidelity, you and I both know that depends on implementation. Active XOs will not turn a poor driver into a stellar one just as a passive one won't. I will emphasize one point. If one decides to go active, one had better be damned sure he's chosen the right drivers and knows EXACTLY where it's flat and where it rings and that means the spider and enclosure too, especially for woofers.
Using a poorly designed and implemented active crossover will give you the same level of signal degradation as an equally poor source. Now if you say sure that's analog active XOs but not digital, think again. Digital active XOs face the same problems. The engineering has yet to achieve the theoretical potentials as our very own WBF engineers all point out. Again, it is an implementation issue.
Just the first two technical cites from one of your earlier posts (there are others):
Headroom
Driver control (damping)
Those are big assumptions Tim. Assumptions not in line with the language you've been using to extoll the virtues which I am not refuting. If anything, my objection is the way the approach is being bandied about as a silver bullet. It is NOT. There's no such thing passive OR active.
Where we differ is my perspective is more on external active systems and yours solutions where all the user has by ways of control are a gain control or two (monitors). In the latter, you've handed the designer the reigns. Not the case with the former where there are way more variables to be studied yourself. What driver to use, what is it's optimal operating range, how is it mounted, what are it's mechanical roll off characteristics, what amp should I use, what slope, what slope(s) for the driver next to it depending on the same things above? All this to only fall apart because the active crossover is imprinting itself. Make no mistake, they all do it's just a matter of degrees. If you can't hear it or get used to it, that's fine. Just don't make it look like because a system is active (direct connection from amp to driver) suddenly straight wire with gain has become a reality. You may have removed the passive XO but in it's place you've added gain stages in the signal path. An active XO for stereo will have a minimum of 4 gain stages.
Nothing to wager, jack. Of course it's about implementation. Of course a poorly designed and executed active speaker can sound bad and a well-designed and executed passive can sound good...great, even. The topic is the sonic benefits if active crossovers. I think "benefits" assumes good design and implementation. Do you think there are none? Do you think if a speaker designer took his own very well designed and implemented speakers and created an active of equal quality with the same acoustic (cabinet, drivers...) components, that there would be no sonic benefit? Because I have heard several designers, a couple on these pages, comment otherwise. We'll probably never have the opportunity to do the comparison so it's pretty theoretical, but do you really think there would be no benefit? Would there be a sonic benefit to the passive version, then? What would that be?
Tim
There's no denying that. I'm talking about a performance gain, a comparative advantage that comes from the passive approach. I've been in a few of these discussions; can't say I've ever seen anyone come up with one.
There are plenty of active line-level crossovers that add much less distortion than a simple passive speaker crossover.
I don't quite follow. In that system, what is the performance advantage of using a passive speaker crossover instead of an active or passive line-level crossover (analog, for the sake of argument)?
I reviewed and didn't find anything particularly technical in my posts, but I'm flattered, even if they were technically flawed.
It's a tough comparison, no doubt. And I completely agree with Jack that an active speaker is best designed from the ground up, not converted from a passive design. One thing always seems to be missing from these discussions, though -- the inherent advantages of passive design. I'm not talking about the flexibility to upgrade/change/choose electronic components, or the fact that there are really good-sounding passive systems. There's no denying that. I'm talking about a performance gain, a comparative advantage that comes from the passive approach. I've been in a few of these discussions; can't say I've ever seen anyone come up with one.
Tim
That's easy. Cost.
BTW you said "I think "benefits" assumes good design and implementation.". I don't see how suddenly I can be dead wrong man. Face it. Active or passive, the RIGHT answer is "It Depends".
I would like to know how that could be?? Please explain how the signal going to a tweeter, typically through one cap and a resistor could generate higher distortion than multiple gain stages and literally 10X the number of passive parts.
It just doesn't make sense to me.
Rob![]()
