I have oftentimes stated that my preferences is not the Equi=Tech (love the name). This should not be construed as a defense of blanced electrical power. A better understanding of the issue would have required a drawing maybe some other time. But there is some noise cancellation in a balanced power system. let's make it simple. if you were to measure the voltage between the two legs in a balanced power system it will be 120 Volts. if you measure however the voltage from one of the leg with respect to ground it will however be 60 volts. The voltage in each legs are in opposite phase with each other thus any noise in the legs cancels themselves to ground ... There is some noise cancellation
Frantz,
I love when people who many times defend engineering deny simple vector calculus saying let's make it simple ...
The issue is really more complicated than you are assuming.
I've always heard others claim that isolation transformers leave a coloration. The Torus does not. There are only advantages as far as I can tell. I have had the Torus rm60 balanced for a few months and I've been happy. I plug everything into it. I separate digital, dac and amp on each of the 3 trafos. The noise floor is non-existent, dead quiet and the current flows. It's particularly apparent listening at higher volume with complex music. Everything stays in place and dynamic passages come off more effortlessly. I don't worry about my system when a storm comes through. The electrical was minor. Since I already have 10\2 romex, I just had my electrician set up my circuit 30amp 240v for the torus which uses a washing machine outlet. Electricians call it a "china man" face. The Tous rates each phase at 20 amps, 120v with dynamic current availble more than 100 amps per phase; way more than you could get from a wall. My Soulution 710 sounds better on the Torus. In fact, I sold all my expensive and massive Elrod cords!
Nyal's heard my system; he could say whether he thinks it lacks dynamics or speed plugged into the Torus. ;-)
so please educate us... We are all ears.
The balanced signal from the Equi=tech is NOT balanced in the way most audio signals are. Audio signals have usually common mode noise, as they are created by equipment having the same power supply and similar electronics characteristics - the noise signal will be the same in the two phases. A balancing transformer will NOT transform the mains input noise in common mode noise - it will invert the signal and noise, making both differential.
My understanding is that the benefit of using balanced audio cables is that they reject most (if not all) of the electrical interference pickup up by the cable through the air, i.e., the RFI, rather than any noise from the gear itself (unless it happens to be airborne). This is why they're most often recommended for longer runs: the cable acts as an antenna for airborne RFI, so the use of balanced cables helps mitigate that.
Assuming my understanding above is correct, then it seems reasonable to me that it would also apply to balanced power lines.
How big is the unit, where in your room do you house it and what's MSRP
View attachment 7898View attachment 7899
http://www.toruspower.com/wp-content/uploads/2013/01/Torus-Models-List-USA-4-pg-2012dec28.pdf
I don't know about pricing. It's expensive. But still a lot cheaper than fancy power cords.
here's what I found
http://www.elegantaudiovideo.com/pr...e-Input-Audio-Video-Power-Isolation-Unit.html
what is the difference between the RM 60 BAL and the CS 60 Bal
Have you ever bought from them before? You on your own if you don't get it from a dealer.![]()
Take a relax. I did a search and that's what I found. I'm not the least bit interested in this unit
