I'd buy a condo in FLA..
What makes you think it doesn't impact sound quality? you don't believe that quality of the junction between cabinet and driver has an influence? I was also shocked when I saw the MDF screws... so shocked that I had to email EA to make sure I was unscrewing the right screws.... Btw, you have the same screws for the back panel with the amplification module.I am a complete novice to the ultra high end game, and cannot compare my EA MM3s with anything else in its price range sonically. However, I do agree for a speaker this expensive the quality of build is underwhelming. I make this comment because when I replaced a woofer, much to my dismay I found the woofers are screwed straight into the MDF cabinet, using MDF screws! This caused some problems positioning the woofer for assembly. I would have expected threaded inserts and bolts.
Of course, this does not impact sound quallity, so from a sound quality perspective this may still be a "cost no object" speaker, from a build quality perspective it is not. Lets hope I won't have any delamination issues down the road. Certainly won't be shipping air.
A new pair of X-2's are "only" $70k ! Think of the money you'll be saving!![]()
I like also the TAD, good choice.
What were you repairing ...?
Yes A.wayne, stereo mentioned all those points in one of his previous posts, just few posts back.
--- :b
I wonder if a pair of MM7 could be made with a custom finish, without the internal bass amplifier and with an outboard active crossover for the bass towers or if the internal bass amplifiers somehow could be bypassed and still use the internal crossover?
If so I wonder how that would compare to a pair of Rockport Technologies Arrakis 2 with a pair of Wilson Thor's Hammer and a pair of Wilson The Controller opererated in mono.
Set it up Lloyd , get all three together ....![]()
They may not want to manufacture it without amps and their own crossover, but you can always do that yourself. Just open it up, cut and bypass wires and your set.
A custom cabinet finish is another consideration, and they may be amenable to it for a price.
Sorry, my intentions were not really well described in that post. it should have been like this:
1) I wonder if a pair of MM7 could be made with a custom finish, without the internal bass amplifier and with an outboard active crossover for the bass towers or if the internal bass amplifiers somehow could be bypassed and still use the internal crossover?
2) I wonder how a pair of MM7 would compare to a pair of Rockport Arrakis 2 with a pair of Wilson Thor's Hammer and a pair of Wilson The Controller operated in mono.
