Some of the differences in sound quality between player softwares have been attributed to how the software uses CPU power.
Lee
Lee
Lee
Probably true, but the there should be little variation in users who have the same software installed..so all Pure Music customers using a Mac
should not have a huge variance in performance..what DAC they are using would have a bigger impact.
I suspect never. Apple has had a long history of sticking to formats it chooses and nothing else. On Windows for example, WMA libraries are standard. Yet iTunes would re-encode WMA files into AAC instead of playing them as is (double lossy compression is not a good idea).Now, back on topic. When is iTunes going to support FLAC?
It seems that iTunes 11 has removed the "display duplicates" feature, unless it is buried somewhere. I would not have upgraded until they fixed that.
