Ron, if you're serious, I'll work on it.Ken, if you arrange it, I'll come down and I'll drag Steve with me.
How do I know? By listening my friend.
For decades to live music and hi fi equipment. As for what measurements effect imaging. I'm still waiting for Ethan, you ,or anybody to give my a specific example of how to look look at a specific measurement and predict how that speaker will image. I will not be embarrassed at all. I'll put it to immediate use.
BTW if you went to Harmon you would be listening in mono to a test tone or 15 second music clip.
You have pretty strong views based on words above.Maybe. Probably.
The answer is in reverse. Measurements can show defects. Once they show defects, no listening test will tell you anything better. If I measure a woofer, and it tells me that it doesn't reproduce anything above 1 Khz, then that is it. I will not entertain anyone saying we should listen to see if that is indeed the case.I'll put it back on you: What aspect of how a speaker sounds do you believe cannot be represented using measurement data?
I think I said everything probably coukd be measured, it just has not been done yet.
Could you please take a look at these graphs of the Aerial 20vt If you could point out if there is anything there that would tell me about the speakers imaging characteristics.
how accurately the pair match.
You have pretty strong views based on words above.You make a living from audio reproduction and recording and you say that you "may" be able to deduce what you need from measurements. If so, where does that leave our forum members???
Speakers in this sense are a nightmare. Their measurements are so varied that it is very difficult to compare just two graphs and decide a speaker sounds better than another ... In 1 second I can tell if a speaker is too bright. It takes you longer than that for your eyes to focus on the charts.
Maybe we should begin where we do agree. First that signal integrity within the signal path should be treated with the utmost care and respect.
Ok. you can't do it. Please feel free to select any set of measurements for any room and speaker of your choosing and show me how to calculate imaging. Make up some hypothetical measurements if you have to. Otherwise this is fruitless.
But Ethan, are we speaking in purely theoretical terms? As a practical matter, there are several obstacles:I agree there too. Speakers vary in so many ways that it's very difficult to measure everything needed. But that's not the same as saying that measurements cannot tell the whole story. They can indeed.
Even skilled speaker designers have stated that correlating the many measurements necessary to assess speaker performance is not only challenging, but requires listening sessions to confirm (or not) that the speakers are performing as the measurements, and meaurement interpretation, would indicate.
As an an acoustician iI would think you would have countless sets of room and speaker measurements you could point to and say this causes good imaging.
i don't think anyone on this forum would be surprised by how harmful first reflections can be depending on the room size and speaker distance from walls and ceiling. the smaller the room the more significant the first reflections effects are.Note that the terrible response shown in red changes with small head movements. So it's not only that the response with reflections is lousy, the peak and null frequencies also change if you move your head even half an inch. The response is also different for each speaker for any given head location when early reflections are present.
This paragraph addresses both aspects of the issues under discussion. In reverse order, preference is, well, preference and no one is suggesting one should prefer one system over another, at least in the abstract. I know Ethan has repeated this in many of his posts. So, is this then the end of the discussion? If it is, it has many, many consequences, both intended and unintended, for the entire industry, both pro and consumer. Arguably, we might as well shut down this site because all we are discussing here are personal preferences:So when I see the words true or truth with regards to audio fidelity, the sheer absolutism is something I regard as either cock-eyed optimism at best or at worst the very self delusion you attribute to audiophiles and yes, homeopathic adherents. Regardless of the methods you employed in choosing your equipment or in preparing your listening environment, the bottom line is that in the end you chose a system that works best for you.
The problem with this "sounds better to you" approach is that it is not transportable. Not transportable from system to system, listener to listener, track to track, mood to mood, or sometimes not even from moment to moment. Change something--anything--about the system, the set up, the room, or the listener and all your careful choices may go out the window. For some careful listeners who are actually more interested in at least sometimes being able to just listen to music rather than fiddle with adjusting the equalization, this is enough to cause them to give up on trying to apply electronic EQ to their home listening.
Others, seeing this peril, settle on single or very few target equalization curves which they or some trusted expert in their lives have developed and more or less just "set it and forget it." When I use electronic EQ at all, I tend to fall into this category.
Still, the question remains as to how do you know when you are making progress? Some folks think they just know when a music system is more life-like. They claim to have the sound of an orchestra playing in their head. Audio designers Bob Carver (Carver, Sunfire) and Arnie Nudell (Infinity, Genesis) have claimed this about themselves. For such folks, accurate musical reproduction is like some judges talk about pornography: they know it when they see/hear it. My interjection here: what a great line!
Then there are those who just know the way they like their music to sound and they apply equalization of a fairly heavy-handed nature to make sure that most everything they play will have that sonic flavor--say, for example, lots of bass and lots of high frequency "air." There are potentially as many flavors of "sounds good to me" as there are people setting up electronically equalized home audio systems.
Then there are those who want "flat response" from their systems and are willing to live with the unvarnished, naked truth about any program material, even if they have to grit their teeth to bear it. They seek "the truth" about the recording and are willing to listen through any unpleasantness to hear that truth. They also seek maximum differentiation in the sound of various recordings, believing that the more the sound of recordings vary, the more truthful their system must be in reproducing exactly what is on the recording.
Another type of EQ user is the one who wants the sound of music, tonally speaking, to mimic to the greatest possible extent, what one would hear at a live unamplified concert in a good hall. I tend to fall more into this category than any of the others, I think. One way to be able to move your system sound toward such a goal is to attend a lot of such concerts so that you have a decent aural memory of what various instruments really sound like. That's me.
Even Sean has said that final testing on their products are done by a panel trained listeners. His works billion dollar company with perhaps the largest R&D for audio. I think this shows that the human ear and brain can do things a mic and a program can not.
I've posted this, before, and it bears repeating: there is no standard when it comes to music mastering. To quote Sean Olive, commenting on Toole's Circle of Confusion, "Since the playback chain and room through which recordings are monitored are not standardized, the quality of recordings remains highly variable."
Sean concludes "As Toole points out ...., the key in breaking the circle of confusion lies in the hands of the professional audio industry where the art is created. A meaningful standard that defined the quality and calibration of the loudspeaker and room would improve the quality and consistency of recordings. The same standard could then be applied to the playback of the recording in the consumer’s home or automobile".
Until that time, compromise, based upon user preference, is the order of the day, and not some mythical absolute.
Imaging is more about room reflections than the speakers. Any competent speaker can have good imaging if the room is treated to avoid early reflections.
--Ethan
So how about you write a tutorial on all of the above in your section? That is why we created the departmentNo, I'm speaking about practical measuring and interpretation as well as theoretical. If the average consumer doesn't know how to read a polar plot of frequency response versus angle, or distortion versus SPL and frequency, that's not a fault of measuring proponents.
