Hello Michal
I would like to thank you for this great dac you do. Really fantastic.
I try 2 units home but unfortunately couldn't keep one.....
I'm leaving in France where the voltage is 230v/50Hz. The Dac is very sensitive to electrical interferences.
Sometimes the fact turning on some home electrical appliances causes micro cuts in the dac.
Some other Mytek owners have the same problem.
May be the power transformer is not shielded.... I dont know....
May be you have an answer to this anomaly?
Thanks
JClaude
Hello Michal
Thanks
JClaude
Below is quote from opus111 in another thread it might shed some light on your problem. I have the Mytek in my system and have not experienced any of the issues you describe.
"the Mytek guys either don't know about common-mode conducted mains noise or have engineered their design cleverly to avoid it. They're using an off-the-shelf mains filter block (chassis mounted, top right) and then a toroidal transformer. The upshot of this is plenty of coupling of external mains noise to the internal circuit ground. Using an standard filter 'brick' means there are going to be Y-caps (mains to earth) and so the filtering quality depends on how clean the provided mains earth is."
"PS I'm conjecturing here but probably Bruce already has industrial strength mains cleaning technology installed so won't be worried if kit doesn't provide its own filtering. The average domestic user hasn't heavily invested in mains purification kit."
Hello Rob
PS: Could you develop about Brice' Kit please, I don't understand what is.
I'm still not quite clear on myteks output balanced design. Can anyone confirm me if this unit is a truly balanced design?
Another thing that I'm a bit confused, with my setup, that is with Audionirvana+, I'm not able to have pure DSD (with all kernel bypass on the OS and the so called holly grail DSD logo on the DAC's display that so many folks talk about), correct?
Nor able to listen to DSD128, correct?
In order to do so I would have to go for windows and ASIO, correct?
Prefered connections on:
Windows - USB2
MAC OSx - Firewire
Is that correct?
Does anyone know if the so called problems on OSx will ever have a solution that will see the light of the day? Can that be expected?
As anyone compared this DAC to say the PS Audio MKII PWD? Or any other in that price range? For PCM obviously...
I don't know if I should go for the Mytek or wait another two years to see what will be the future DAC that PS Audio is working on at the moment. It seams a truly promising project, although no one knows the price tag at this stage. But I'm willing to pay for a higherendish DAC that would be more "compliant" with my remaining gear.
I'm just not willing to go for MSB, DCS, Playback-Designs or EMM Labs price ranges... Although they really sound good!
My current setup is composed by JRDG Model 6 w/ BPS-6 + Synergy IIi + Monitor Audio PL-300 and I'm really curious to see how would the Mytek work on my system but I'm afraid that I'll be spending more money on another DAC that once again won't be satisfying enough for me on this setup.
What are your thoughts?
Great to have you aboard WBF!
I have a MAC but have not tried the Mytek with it, so I cannot comment on that side.
I am running 2 Windows machines. One machine is with Pyramix and the Laptop is with HQPlayer. Both use the Mytek ASIO driver out via USB2 and work perfectly at DSD64fs and DSD128fs. The Mytek ASIO driver is my preferred reference. I don't want to fool with the DoP protocol, though I'm sure it's perfectly fine.
The DACs I have compared this to are the MSB Tech, Playback Designs, Digital Audio Denmark, EMM Labs, BADA and the Lynx Hilo.. I can say without reservation, the PCM is the best I've heard in all but the Playback and MSB tech, both of which are $$$. Don't cheat yourself and keep waiting for the next best digital box to come out. There is always promise of something better around the corner. For now, the Mytek is the King of the Hill for anything <$10k.
Buy one now... you won't regret it!
Hi,
As anyone ever had any experience on A/B comparison between Mytek 192-DSD DAC and Resonessence labs Invicta?
Tiff
