What's a typical room? You might have lucked out with your room as is but it would be a very different story for say a condo dweller surrounded by poured concrete, CHB and glass. Then there's the issue of symmetry.
I am a playback guy, not a recording guyHello Amir,
Would you have any comment on acoustic parameters to be considered for an optimal tracking room, optimal mixing room, and optimal mastering room, i.e., three separate rooms/spaces with three different functions
Thanks![]()
Well, it depends on whether it is furnished well or not. Dr. Toole goes through a great scenario of taking an empty room and progressively adding the right furnishings to it to bring down the mid to late reflections. Here is a nice graph from that:This almost sounds like saying a typically furnished (i.e., non-dedicated listening) room needs no treatment at all (except perhaps bass trapping?)
I am a playback guy, not a recording guy. So I can't give that advice. From what I have read, for mixing and mastering, folks prefer to have the front of the room and especially the sides fully absorptive. The so called reflection free zone or LEDE came from that school of thought. For tracking, that is just something I have not studied. Likely reflections are good there but again, I am not an expert at all in that field. Perhaps Bruce can opine there or Ethan.
Exactly. The measurement metric for it is an RT60. This measurement is usually reserved for large listening spaces (our home is NOT that). However, in this narrow context it can be used to measure how "reverbrant" the room is. Per previous graph, the target is around 0.4 seconds in the 500 Hz region. If you hit that, then you are within the "typical" range. If you are higher, then more absorption is necessary. if it is below, highly unlikely, it means the room is too dead.What's a typical room? You might have lucked out with your room as is but it would be a very different story for say a condo dweller surrounded by poured concrete, CHB and glass. Then there's the issue of symmetry.
Think about it, we have been listening to music in rooms for hundreds if not thousands of years, did we need acoustic treatment? ...
Wendell
If you have the typical modern living room with many hard surfaces for example, the fact that it is a living space does not make up for the fact that it will be too "live."
As Wendell nicely said, some of the issues we face these days is easy availability of tools to measure our rooms has resulted in too many people acting on data that is not what it seems when we consider how a human with two ears and a brain hears things (vs. a single microphone and a graph). How good your music would sound if we used a single mono mic and recorded it raw? Likely not that good yet that is what we do when we measure with microphones.
I think what he is saying is that for countless years we have lived in closed spaces where reflections are always there. The brain has adapter to use them to better its recognition of what is there. Who do you know that enjoys singing outside in the open air? I think most prefer a shower. Ooops. I said I did not know anything about recording space.![]()
There is another test for that is to have a person stand where the speakers are and speak in normal voice. If the voice is easy and comfortable to hear, then the room is probably good in this regard. The reason this test works is that the human voice has similar directivity to a typical speaker and so it simulates the real thing for us.
Live end/dead end mixing rooms are an idea that doesn't work very well in the view of many people. FWIW, the best control rooms/ mixing rooms I've sat in were not heavily treated. They don't tend to have a lot of soft furniture in them, so they are treated, but with a mix of soft and hard surfaces that sounds much like a normal listening space.
There is varying mileage on that, though, and there are people out there who love to mix in pretty dead air.
Tim
Thanks for the report Terry. I should have been more clear. The 0.4 metric is not a precise number to pick. 0.3 seconds is certainly in the comfortable and recommendation range. As you go below that, you may still like what you hearing but the space will become less comfortable to interact in. 0.2 seconds is probably the limit in that regard.
One other guideline I have seen from Tony Grimani is to have it range based on volume of the room. Smaller the room, the smaller the RT60. At the 2000 cubic feet, he suggests 0.25, going up to 0.31 for 4000.
The usual way IS to determine RT60 targets. (...)
