Nice. We have been discussing about the psichoacoustics approach and now we have genetics in the debate.![]()
It could be worse .....
Hello Atmasphere,
No feedback or very little ..? i'm not aware of any amplifier being able to have "low"distortion without some sort of feedback ......
Regards,
We use specs too but there is always the issue of what spec is important to the ear and which is not?
So it really becomes a study of how we perceive sound. Its become my theory that the closer we can get the gear to follow human perceptual rules, the more we can get it to sound real.
For example, the human ear uses odd ordered harmonics to figure out how loud a sound is. How loud a sound is is pretty important- IMO one of the fundamental perceptual rules. So we can't add odd-ordered harmonics. Not only does the ear find them objectionable, but it will cause the system to sound louder and brighter to the ear. This is why two amps can measure flat on the bench but one can be bright while the other not.
Loop negative feedback is known to increase odd ordered harmonics while decreaing THD overall. But since the ear is so sensitive to the odd orders, the use of loop feedback becomes dodgy. So our amps and preamps are designed to not make distortion without feedback. That is one of the reasons they are fully differential thoughout.
Bandwidth is another issue. If you don't have wide bandwidth, you have phase issues. For example in the bass, to reproduce a 20Hz signal correctly, you need bandwidth to 2 Hz (1/10th the freqeuncy to be amplified). The measure is squarewave tilt- the tilt on top of the squarewave allows one to see a low frequency problem. If you can deliver 20Hz waveforms without phase problems, you will have greater impact. The ear does not hear phase in a sine wave, but it certainly hears phase issues in frequency bands and also it is used to create a proper soundstage.
Because many of the specs were created decades ago, they frequently don't have a lot to do with the human perceptual rules, as most of that information has only began to show up since our measurement standards were put in place. This has given rise to the objectivist/subjectivist debate, as the specs simply don't reflect anything meaningful in many cases. This is why an amp that measures poorly can sound good and vice versa. IOW the specs (these days at least) represent a sort of Emperor's New Clothes- they are there to make the product look good on paper rather than make it sound better. Another way of putting this is that we frequently measure things that are not important to the human ear and we don't meausre things that are. I am hoping we will change this as time goes by. We certainly have the computing power to do it now.
Due to the human perceptual rules and the use of feedback, I had to take a good look at what is important- make the amp work with a lot of speakers, or only make it work with speakers that have a chance of sounding like real music? The measure of that of course is 'does the speaker require the amp to need feedback in order to work?' If yes, then the speaker will never sound like music due to the problems outlined above. There is more at this link:http://www.atma-sphere.com/Resources/Paradigms_in_Amplifier_Design.php
Definitely, you can have low or acceptably low distortion with zero feedback, and it's hard to argue there are not perks to doing this,
Look at output impedance vs speaker impedance, historically ESL'S tend to have fairly high impedance in the bass/ midrange area , only dipping low in the extreme high frequencies .
OTL's tend to have high output impedance unless tons of parallel output tubes , IMO would not be a good match for MBL's or MQ5, but you may like it , no one can predict such .
Regards,
Thanks. I wonder if Atma-sphere would agree with you... Many would also avoid mating tubes and stats, though, without even trying.
Magneplanars (notorious for having a VERY low impedance at some frequencies). An amp that can't double down WILL have trouble driving Maggies and other difficult speakers.
I am no guru, so I'm not sure whether you want my opinion.
If I knew how to use an oscilloscope, I would probably do so when testing amplifiers. Unfortunately, I can only go by the specs provided and JA's measurements. I've tried a lot of different amps and I keep score of the measurements and compare with what I hear. In my case and with my speakers, output impedance is one of the most relevant specs. Unfortunately, there's no standardization. Is output impedance measured using standard size speaker cable or at the amp's binding posts? Is output impedance the same throughout the frequency spectrum? Does it vary with load or power output? At the end of the day, I can only decide based on listening. Having said that, specs CAN be useful in winnowing down choices.
I don't think output impedance is the ONLY spec that matters. But, it really can help to narrow things down. I have yet to hear an amp that sounds remotely good in the mid-bass with my speakers with an output impedance more than .2 ohm. However, I've heard Hypex class D which has ultra low output impedance and it sounded mediocre in the HF. Some of these things can be inferred from the amp's design; How many output devices? How much feedback?
I was recently looking at a solid state amp where the dealer website claimed a super low output impedance (significantly less than .1 ohm). I then went to the manufacturer's website which claimed a super high output impedance (.4 ohm). The dealer admitted that the manufacturer's website spec WAS correct, not his. The dealer tried to convince me that a .4 ohm output impedance was very low for a solid state amp. That's absurd and I told him so.![]()
(...) [Incidentally, with Class-D amps like the Hypex's, it's a whole lot more complicated.
As far as I know they have a pretty good damping factor, they just don't sound as good as one might hope... ] (...)
DACMan
i beg to differ, magnepans are an EASY load* even for tubes which is partly why if you were a ARC dealer back in the day you also carried Magnepan and they were distributed together almost since day one. its more like a constant load @ 4ohms regardless of frequency. i had to dig deep to find a review with JA's measurements on any magnepan that indicated otherwise. the MG3.6 barely dips to 3.3 ohms:
"The speaker's impedance (fig.1) approximates a resistive load of around 4 ohms over much of the audioband. However, there is a slight magnitude peak centered at 1.6kHz, due to the crossover between the ribbon and the midrange diaphragm. The minimum value is 3.3 ohms at 10kHz, which is not going to be problem for any good amplifier to drive..."
*pure ribbons and electrostats are another matter, original quads go down to 1 ohm and the apogee scintilla a 1/2 ohm![]()
Dacman,
The benifits of class-a is dubious ..or did you mean to state the amount of class -a as oppose to class - a itself ..
Regards ,
DacMan clearly stated that the benefits of Class A operation are dubious which I find to be an interesting comment. Maybe we should take his statement about Magnapan speakers being a very difficult load for an amplifier to drive in the same light as the Class A statement.
I also don’t believe his statement that “most” well designed Class A/B amps double down their power as the impedance is cut in half. Many amps come close, but they don’t actually double their power output because the power supply just can’t supply the necessary juice. Take a look at the specs of “most” well designed Class A/B amps again and tell me that most of them truly double down in power output. They don’t. And close doesn’t count except in horseshoes and hand grenades.
