For a $1,500 vinyl rig - a package or components for a frugal audiophile?
caesar
970
1,698
A friend wants to spend about $1,500 on his vinyl rig. He is wondering if he should get something like a Clearaudio package or if he should mine Audiogon and assemble his own system. His musical goal is to get jazz to sound "as real as possible".
Any suggestions for my frugal audiophile friend?
Go for used and get a VPI Scout or Clearaudio Concept
don't forget the phono stage...a bit more dough needed for the pot.
I've heard spending some dough on pot makes for a better sound:)
Tell your friend to support audio by not buying a product that violates any patent of a smaller manufacturer. You guys keep mentioning such a company.
I'm not sure you can get the magic of vinyl cheaply, although admittedly i haven't heard the latest crop of 'entry' level tables. And when you add cartridge and phono stage, it's gonna add up.
I haven't heard a Grado MM in years, but those used to sound very musical back in the day. Used VPI might be the way to go.
I had a Well-Tempered back in the 80's and thought it was fabulous for the money. Don't know what the new ones perform like.
And used EAR tube phono stage could work, I gather they can be modified and tube-rolled. But that may be more of a commitment, in terms of effort, than the person wants to get into.
Mosin, you implied bigger company infringing. Is this a known fact in the industry?
I gather you are being cryptic because you don't want to make a public accusation. just curious.
Yes, yes, and yes.
VPI Traveller at $1299. stoopid good for money.
tru dat!
Add a Grado Reference Platinum 1 (MI) for $350 and you're in business, unless of course phono stage is required.
