Mark -- 150 A @ 240 V!!!Please tell me that's not for your home system...
Uh, yeah, it is. Assuming I had the breaker capacity, the system could top 200A load with sine wave test signal at full power. Each QSC amplifier can pull 92A and the Haflers, in the config I use, can pull close to 20A each.
What is Star Grounding? Never ever heard this term before.
John
John
Scary, Mark, but I bet it sounds great! I'm guessing headroom is not a concern...![]()
Running all ground connections to a single point "master" ground. Think of all the ground wires from all components coming together to a point in the middle like a star with the wires comprising the points. Assuming that point is the lowest-impedance (best) ground, this will minimize interaction among components since all ground current flow away from each other and into the star ground.
HTH - Don
