So ok 384KHz can sound better that 192KHz on a given DAC, but is it better than 192KHz played by a Totaldac D1?
Hi lloydelee21,
What does SOTA mean? The LP table manufacturer?
For PC users I recommend the D1 USB input. If you don't want to use a computer you can also use an audio server, like Aurender S10 among others, in this case I recommend to use the AES-EBU link for the best results. And if you want a CD drive yes indeed they make a difference. I have no specific recommendation but I recommend also to use the AES-EBU link which sounds better than coax with the D1.
On your site you show impulse response in 44.1 KHz with FIR filter on and off, but what about 192 KHz?
What's the Linearity of the D1, -120dB or better?
It's an Elrod. I had 3 Elrod X2 PCs. I sold 2 of them and I may sell my last one. The soulution has an IEC that is 90 degrees toward the right binding post. I can't plug the x2 into the iec without using an adapter. I don't like the adapter, so I may just sell my last x2 also. I am using the stock PC with the 710, which is good. The better my system gets, the less the PCs matter, IME.what's that drain pipe of a power cord brand ? Great looking system by the way.
It's great! It has a tube-like 3D soundstage, super fast and very accurate. I thought I needed an amp with huge wattage/power. I was wrong. I've discovered there is more than one kind of power. Maybe control is a better word. The soulution can maintain very complex music at high db without losing it's ultra-accurate sound or instrument separation. It sounds effortless at all levels; doesn't run out of steam. Bass is very tight and correct. No overblown midbass. It's also super quiet which means abundant low level texture and spatial info. It also rocks. No harshness. The music I once thought was too poorly recorded for listening shed the harsh edge and is musical again. It's like a tube amp but with the ability to really control the speaker.What do you think of the Soulution 710?
