I realize now that I should have started my own thread, should have asked a much narrower question about the technical requirements for properly driving an amplifier. That question was answered here, but a lot of others were raised by the way I went about my inquiry, pushing so hard on the how and why, and not just accepting people's experiences on face value. I'm helping a friend put together a single-source system. It will be different - bigger - than my own, and I wanted to know if, once the source has sufficient output and a quality volume control, there is any substantive advantage to adding a preamp.
The answer, it seems, is "Yes. If you hear one." Unless you have the money to buy a roomful of quality pres to switch in and out of a system until you're satisfied that you've answered that question and sold off all, or all but one, or unless you're willing to displace at least a part of your love of music with a passion for years and thousands of dollars in the pursuit of system synergy, it's not an answer. It's another whole series of questions. I guess I was really looking for "your output x needs to be between A and B if your amplifier z is between C and D." Can it be that simple? Perhaps not, but I think it's a lot closer to that simple than it is to this complicated. YMMV.
When I got subjective evaluations of emotional experiences instead of my answer, I pushed for data. That got interpreted as me not excepting people's experiences. The truth is I probably asked the wrong question in the first place. Sorry.
Tim
PS: Looking back through, I see that my question was answered, pretty definitively, by page 5. Had I bowed out at that point instead of challenging people to provide some substantive explanations for subjective experiences, this whole thing would probably have ended better. My apologies.
Tim,
Thank you. That is very gracious of you. I thought that you just wanted to draw this back down into what can me measured.
I have the same problem - I thought that if you got a source component with a low enough output impedance, and a power amp with a high enough input impedance, the preamp and the interconnect would not matter. The generally accepted ratio is 10 times. But I've gone to 20x and even more, but it still does, and I don't know why - I suspect it has to do with the power supply of the source component, but then how do you measure this? You build a better power supply for the source component of choice.
My Weiss DAC2 (Minerva) with volume control has a power supply for the analog output that is over 5 times more than the original. All who have done a direct comparison with the DAC202 here have said that it sounds better even though the DAC202 sounds quite a bit better than the standard DAC2.
However, with a superlative preamp, it still sounds better using a preaamp.
The three best DACs with volume control I have heard (and did extensive testing in my own room while I was deciding on the DAC to bring to CES this year) were the BADA, MSB, and my own Weiss. In all three cases, inserting the SMc Audio VRE-1C improved the sound TO MY EARS (and also to my sister's ears and those PNWAS members that visited to help me decide).
Why? I don't know. The power amp has an input impedance of 75k ohms balanced, so any of those DACs would have a low-enough output impedance to beat the ratio. Interestingly, the VRE-1C has an output impedance that is HIGHER than the BADA.
Another example, on Thursday night, Todd Garfinkle was in town with his highly modified Korg MR-2000S. He brought his high-rez recordings (5.6 MHz DSD) and we were setting up the system prior to the meeting. He was using the stock power cord supplied by Korg. And the music was good, and palpable.
On a whim, we suggested using one of the audiophile power cords we had. The shock on his face was palpable. You could see it in his eyes that he thought his recordings would be improved if he had that power cord. His comment was that it seemed that the musicians had more energy. He said that it was the biggest improvement any cable had ever given him.
We took the cable off and went back to the cable he started with, and it went back to as before. Putting the cable back in, we got the same improvement. Needless to say, he left for home with the power cable in his bag.
Why did that happen? A power cable?? I don't know either. But it made a difference - and this was to the recording engineer who was there during the musical performance.
