we all have to play the cards we are dealt with.
Such is life. On the bright side, it gives you something more to work for.
Unfortunate set of dimensions. Multiple of 8 feet in all three dimensions means some really nasty and non linear response in the bass. LOTS of bass trapping and room correction will be necessary to extract the most from whatever speaker you use.
The X2 series 1 upgraded to series 2 saves close to $15K. From what I understand, the Series 1 midrange, tweeter and crossover are changed to match the series 2. The cabinet is the same save for the difference in appearence from behind. Are there any other differences ? Will the series 1 upgraded to series 2 sound every bit as good as a current series 2 model ?
The upgraded series ll is sonically identical and indistinguishable from an x-2 series ll. only difference is the glass back showing the resistors
Okay, now the butterfly's start until I get the ballz to Call Paragon. I'm thinking they will take my Watt Puppy 8's as a trade in. I bought the 8's from them.
You'll never look back. It is a night and day difference in all regards
I am now a proud owner of X2 series 2 in Almandine Black with black hardware and black grills. It is a purple very dark hue metal flake. They took my 8's in as trade and will arrange for them to be shipped back (Paragon will come out for install)....I am in euphoria right now....what a deal !
