Shostakovitch 5th Synphony, last movement - plenty of energy! A serious test for any system.
Tim I was responding to this post of yours.I get that, Ethan. 16 bits, 17 bits, I'll bet most of these middle-aged guys can't hear the noise floor at 12 bits, but we dom't deal with we hear, in high end audio...well, unless,of course, what we measure and test defies the conventional wisdom. Then it's all about, only about what we hear. or think we do.
Tim
Having read a good bit of the thread my conclusion .. It is not a bad idea.
24/192 as a matter of fact is a very good idea. Given the availability of inexpensive storage ( 1 TB is presently about $70 in the USA). ADC and DAC working well in the region and no clear proof that the ultrasonics cause so much problems , I would err toward an inexpensive "more" rather settle for the baseline ...IMHO of course
Can we design a test to actually illustrate the loss of low signal level detail on 16bit Vs 20 or 24bit? I'm thinking of a null test for instance! But not a null test that uses an ADC to record the analogue output!
See I'm a measurements person after all![]()
If we did a DiffMaker between the two files could we listen to the Diff file for a clue into the audibility of this difference between the files. My thinking might be off here as I know that it's instrument tails, air & venue ambience, etc. that is being talked about in this "resolution" & these sonic cues, divorced (as they would be in Diffmaker) from their surrounding context may well seem trivial & insignificant. But I don't really know. has anybody done this sort of test?Just take any good "true" hirez file and dither it down to 20 and 16 bit. Put the files in a workstation and invert polarity against your reference.
Related topic but not exactly from "Residential Systems"
Dolby TrueHD 96k Takes Blu-ray Audio to 11
http://residentialsystems.com/blog/75532.aspx
Might want to start a new Apodizing thread for that one.
This is getting around. Maybe we can all talk about it over at "When is Hi-Res not really Hi-Res" topic![]()
Or again ... :b
This one of three threads to which I subscribe, and all have more or less fused into the same discussion.
