To bring a smile to someone’s face perhaps? It’s clear from tag line who I am… perhaps I should have used a different emoji!Hi Nigel: Why are you referring to yourself in the third-person?![]()
All the best
Always good to keep the thread about the gear, not the people.Hi Nigel: Why are you referring to yourself in the third-person?![]()
I recently heard the double SwitchX + WifiX setup at the Capitol Audiofest. It was connected to a portable T-Mobile 5G WiFi Router upstream and an Innuos Zen Next Gen Music Server. The Zen Next Gen was connected to a Thrax Enyo MKII all in one Integrated Amp/DAC-Streamer/MM/MC Phono via Final Touch Audio Meis RJ45 CAT 8 cables.While they use the off the shelf chassis (for cost effectiveness) the inner workings and added power supply are anything but. The noise sensing and noise cancelling circuits are unique and very effective. The internals of the switch have separate and isolated clean and dirty sections.
With all of the discussion around the NA Tempus Switch, it would be great if someone has compared the SwitchX to the NA Tempus.
Nimbly skipping past your process for narrowing it down to just these twoI'm also in the market for a higher end switch and narrowed it down to these two. From a 'value' perspective seems like the Tempus has a slight edge since they recommend a single switch, whereas the SwitchX performs best with two in series. Now which is better... a single tempus or a double switchX is the question...
It is worth remembering that I have seen the Network Acoustics team recommend having streaming system after the Tempus to their reviewers. So maybe it is not as clear cut as you outlined on dual switches V one single better switch.I'm also in the market for a higher end switch and narrowed it down to these two. From a 'value' perspective seems like the Tempus has a slight edge since they recommend a single switch, whereas the SwitchX performs best with two in series. Now which is better... a single tempus or a double switchX is the question...
For clarity, the latter is for a slightly different scenario and is not meant for direct stacking/daisychaining/cascading.It is worth remembering that I have seen the Network Acoustics team recommend having streaming system after the Tempus to their reviewers. So maybe it is not as clear cut as you outlined on dual switches V one single better switch.
Reiki Audio also have a multi switch system as their leading offering, which tells me do not discount anything, give it a try and see what you hear.
Whatever the switch, if the manufacturer has dealers in the US then the enquirer's first port of call should be to a US dealer who may be able to facilitate a home demo with no upfront payment.Obviously listening to these things back to back is not that simple. Although they all offer home trials, you have to buy them first, so that can be a 10K needed to get for example the Tempus and Reiki Audio switches side by side in your home to try.
I added (chained) a second Switch-X to my system and the difference was not subtle. I was surprised given the magnitude of improvement the first one made.It seems pretty obvious that the higher performing a switch is, the less difference adding a second one in series will make. There are nuances of course but I'd wager this is pretty generally applicable.
Interesting about not needing two switches. I am UK based, but the dealers are not close.For clarity, the latter is for a slightly different scenario and is not meant for direct stacking/daisychaining/cascading.
The scenario: some people consider installing a second router in their home, dedicated to audio. The same degree of separation can be achieved more neatly by adding a second switch directly after the router and hanging the audio chain off this. It's an alternative topology to a separate router. There is no audible benefit from stacking two SuperSwitches just before the streamer becasue the second has nothing to do.
Demo’ing a single Switch X should be more than sufficient to assess it’s effectiveness. I used a single Switch X for 2 years before adding a 2nd one. The single Switch X was just so superior to the many switches I had experimented with over the previous 5 years. And don’t underestimate the importance of WiFi X. I was highly skeptical at first, but I quickly heard how bad a typical home wifi signal can be for your audio system compared to WiFi X.I'm also in the market for a higher end switch and narrowed it down to these two. From a 'value' perspective seems like the Tempus has a slight edge since they recommend a single switch, whereas the SwitchX performs best with two in series. Now which is better... a single tempus or a double switchX is the question...single Switch X should be more than sufficient to I used a single Switch X for 2 years. When I first put it into my system it made a significant improvement, a big leap from all of the switches I had tried over 6+ years.
Nimbly skipping past your process for narrowing it down to just these two...
Of course there is only one way to find out. Step forward volunteers!
Good question. If you haven’t already you should explore the website of Chris Stevens who designs and builds these products. His descriptions and videos are very informative, much more so than any other manufacturer I’ve come across.I'm not sure I fully understand the point of Wifi X. From what I gather, it's a dedicated access point placed on the "clean" side of the switch, used only to control your audio streamer. The idea is that this setup keeps Wi-Fi signals from interfering with sensitive analog audio equipment.
However, I assume you would still need another access point for general Wi-Fi for the rest of the house, connected to the "dirty" side of the network. Wouldn't the Wi-Fi signals from that separate access point still reach your audio equipment and potentially cause interference? If that's the case, I'm not sure what the point of the Wifi X is?
I'm sure I'm missing something here.
I fully agree to this. Have just installed an access point ( Asus) around 9 meters away from the stereo. I could not believe how much adding this move could do for reducing noise, and even better when I changed psu powering it. So this was also very important at least for me.So ideally keep your home network access points as far away as possible from your audio system. And use WiFi X just to control the playback software on your music server.
I made the experience that a second router which is dedicated only to have the audio stream could be replaced by a second switch. The second switch has only one input and one output, manages only the audio stream. For the time beeing I use the Taiko extreme just before the streamer and a LHY AS8 as second switch before. The increase of soundquality in terms of clearity and dimensionality is significant. Btw after tests with Ansuz, Ediscreation, Reiki, Network Acoustic and Melco I finished up with Taiko extrem + DCD + Farad Super 6 as a phenomenal combination as the main switch. For me this shows that a trial at home is necessary to find what could be the best. Because with a stable and good network only small nuances show up.Interesting about not needing two switches. I am UK based, but the dealers are not close.
Do you live far enough away from neighbors such that a scan reveals that no other wifi network is still being beamed into your listening room. I don’t and have been amazed by how many different SSIDs have sufficient signal strength to show up when I do a scan. As such, I’m doubtful that a product like WiFi X would benefit me much.The sound does not change when I turn wi-fi off, therefore my conclusion is that wi-fi is irrelevant in my system, as long as it is only used for control and not directly in the replay chain.
I know it is hard to follow in these longish threads, I think Nigel was referring to contacting the folks at SoTMHi Nigel: Why are you referring to yourself in the third-person?![]()
Six extraneous SSIDs right now.Do you live far enough away from neighbors such that a scan reveals that no other wifi network is still being beamed into your listening room. I don’t and have been amazed by how many different SSIDs have sufficient signal strength to show up when I do a scan. As such, I’m doubtful that a product like WiFi X would benefit me much.
