Analog Magik
@Balle Clorin, and where might we be able to get this script? I like the way the results are displayed.
Here are my scripts, you need to have Python and put the script and file in the same folder. Rename .txt file .py
I hope the names and scripts are self explanatory, I made then by using AI, so I cannot answer technical stuff about them or how to configure Python on a computer. I use Anaconda, Spyder based on the guideline here.. https://www.audiosciencereview.com/...-cartridge-response-measurement-script.41148/
The script used above is called "IMD vs TIME", I also add some other fun scripts
  • thd-vs time19 ortofon.txt
  • IMD AND FFT 315-3150HZ LB202 rev10 fchoice REL-F2 or avg.txt
  • ANYSIGNAL -phasedifF 2harm sweep R6 kladd .txt
  • Generator phase difference r2.txt
  • IMD vs TIME.txt
  • WowANDFlutterGenerator-10db.txt
Thanks. I’m quite familiar with Python and Anaconda.
