(...) Personally, if I were mod of the gods, I'd just delete the whining, leave the science, close the thread and pin it up in the hall of fame. YMMV
tim
Tim,
Are you also going to put this one in your signature?
tim
Soundminded,
Wise decision following a starting comment I also fully endorse.
Although the magazines are not scientific, I suggest you read them, but always with an open and critical mind. One point I found everywhere in reviews and in the net opinions is that the excellence of these speakers only shows in an appropriate system and very carefully positioned. It seems that even technically perfect amplifiers can make them sound nothing special and the choice of the sources (and even cables...) is critical. Good luck with your listening - looking for your opinions soon.
As an example look at this review of the Ultima 2http://www.avguide.com/review/the-revel-salon-ultima-2-loudspeaker
tim
I'm afraid science is not the ultimate determining factor of good sound quality. It fails miserably in describing subjective listening nuances that are the fundemental elements of enjoyable listening experiences. YMMV !
The related sciences of acoustics and psychoacoustics are still in a very early stage of development, both are barely a hundred years old. Come back in a century or two and I'm sure you'll find enormous progress will have been made by then and most of our questions will have been satisfactorily answered.![]()
Try to explain this to those who think that everything was settled 30 years ago and nothing worthwhile noticing is been done in electronics since them.![]()
Oh you can be absolutely certain that if I acquire Revel Ultima Salon 1 or 2 I will buy a Crown amplifier to use with them, I'll buy my wires from Home Depot and the Dollar Store like I always do, and I'll be using one of my $30 Toshiba DVD players and my Empire 698 with a Shure V15V MR like I always do too unless and until someone can convince me that there's something wrong with them. (...)
Are you comparing the LEAP averaging facilities with the Harman analysis software tools? As far as I know LEAP just averages , it has no weighting facilities.
Soundminded,
I am changing my advice. No, please do not try the Salon's - you risk to find that the Empire 698 with a Shure V15V MR sounds much better than the $30 Toshiba DVD player! And WBF will win one more anti-science member.![]()
So based on Amir's views, I'm going to seek out a demo and find out for myself what this is really all about. Who knows, I might just wind up buying a pair. At $22,000 list I should be able to afford them if I really want them.
......and listen to just one of them connected and not facing directly at you.
I wasn't really serious about shutting down the thread. I like thread drift, personally. It works just like human conversation.
See if you can hear some Martin Logan Summits while you're listening. And report back.
Tim
... using no preamplifier and cheap but thick cables.
I'm going to start a business mining the copper plumbing from reposessed houses here in the US. then wrapping it in lambswool and terminating with alligator clips made from real, silver plated alligator heads. Audiogon, here I come!
Tim
Tim
Amir,
Thanks, but I can not conclude anything from a single figure - I have to say that I even do not know for sure what means (a) Live test (b) Binaural test - in this case. I have to see, even briefly , the whole paper. Anyway my point is that I can not find any evidence that the M speakers was listened in appropriate conditions, as my experience is that dipoles are very critical to position and a good position for a box speaker is never a good position for a dipole. Could you tell me , so I will be sure once for all, if the tests of speaker M were carried in mono and with a single speaker?
