The first network streamer ever in the Grandioso range and the first to debut with the second generation of their in-house Master Sound discreet DAC. Details:
- Network Streamer / DAC: Designed for High-End digital music streaming and file playback.
- 4th-Generation Esoteric Network Engine G4: Supports native DSD 22.5 MHz playback; equipped with SFP port.
- Master Sound Discrete DAC G2: New-generation FPGA based Multi-Level ΔΣ DAC, fully designed and manufactured in-house using precisely selected discrete components.
- ES-Link Analog: Esoteric’s proprietary current signal link with preamp, provides super authentic sound.
- Independent ×5 Linear Power Supplies (Dual Mono DACs/Network/Digital Audio/Microcomputer): Provides powerful clear sound.
- Low-Feedback Discrete DC Power Regulator: Contributes to live and open sound quality.
- External Power Supply Connectivity: Compatible with the Grandioso PS1, offering upgradability for even higher sound quality.
- ES-Link5: Esoteric’s proprietary ultra-wideband HDMI cable link with Grandioso P1X SE SACD transport.
- Wide Range of Digital Connectivity: ES-Link5 ×1 [L/R], USB ×1, XLR ×1, Coax ×1, Opt ×1.
- Music Server Function: Two USB drives can be connected.
- Master Sound Discrete Clock for Digital Player: Ultra-high precision internal clock circuit.
- 10MHz Clock Sync Capability: Compatible with the Grandioso G1X master clock.
- Wide Range of Supported File Formats: DSF, DSDIFF, FLAC, ALAC, WAV, AIFF, MQA, MP3, AAC.
- Esoteric Sound Stream App: Provides extremely comfortable operation on smartphone/tablet.
- Support for Multiple Streaming Services: Tidal, Tidal Connect, Qobuz, Qobuz Connect, Roon, Spotify.
- Multi-Layer Chassis: Prevents interference between circuit components.
- Semi-Floating Top Panel: Enhances sonic openness.
- Advanced Isolation Feet: Provides focused sound and an open soundstage
The N1 is also compatible with the Grandioso PS1 power supply, previously only used with the K1X/K1X SE.
Shipping this November.
I placed my order for one yesterday + the PS1 power supply to go alongside the C1X Solo preamp that I received today. Not sure what the pricing will be in other territories but the RRP here in Australia is $59,500 AUD. Keep in mind Esoteric is very well priced here so doing a currency conversion won't give you an accurate picture. The K1X SE is $55K here so use that as barometer I guess.
This to me is Esoteric taking the fight to the likes of DCS, Wadax, MSB, etc. Can't wait to hear it and find out what improvements their second generation DAC brings.
