A passive does not have EQ and it doesn't really have timing. Although the cutoff slope will alter phase.Building a cross over may not be too hard., once one knows what they want (or need)..
Or course know what is needed, and what to build, may be very difficult.
Yeah - but one can apply timing with a DSP.A passive does not have EQ and it doesn't really have timing. Although the cutoff slope will alter phase.
Good point. I just bought that little Dayton crossover.Yeah - but one can apply timing with a DSP.
And using that data, one could likely noodle out how to stagger the drivers mechanically/spatially to achive the delays accousicly.
So once a decent sound is achieved, then iterate on putting the drivers in some “box” to match.
REW can use external signal with loop back to the software. A sine wave sweep is better as it can then be transformed into an impulse response.Why Bluetooth. Qobuz has pink noise. A laptop with REW and a microphone don't need a connection to the audio system or DAC? Do they?
Mixing amp technology for active biamp usually doesn’t sound very good. At least get a second Blade amp. I thought you had concluded that the MF amp sounded like crap anyway?I got a Daytoon Audio DSP 408 and tried it out. Interesting. Very different than passive. I tried biamping with my Musical fidelity A3cr and the Blade tube amp. I did this before, all passive. The stock crossover has biamp capability. It was a disaster. The bass was heavy and thick and out of balance volume wise.
With the DSP 408, I used only the A3cr through the DSP to the 15 inch woofers. The Blade tube amp still went direct to the passive crossover and was fed direct from the preamp. The Blade powers the 10 inch and the horn tweeter. This time the sound was?????? It wasn't thick. It wasn't thin. There was more bass, but it was not better bass. I then put my horn sub through the DSP. When I added that in, I was shocked how much more natural the bass sounded. Much more real. This was not at all what I hear when I have the entire speaker through the tube amp. With the speaker all on the Blade tube amp, the bass becomes more pronounced with the horn sub, but it is more natural and real from the start, so that does not stand out as an attribute of adding in the sub.
When I turned it up, it got horrible. Just gross. I turned it off and walked away. I need to go back and test some more. I also need to get REW set up on my laptop and start using an AI to model my speaker placement. I think what this taught me was, my setup really sucks. My room is a disaster.
Sounds like the first time you tried this with the stock crossover, you needed to do some level matching (your description sounds like the amp driving the bass was making too much power).I got a Daytoon Audio DSP 408 and tried it out. Interesting. Very different than passive. I tried biamping with my Musical fidelity A3cr and the Blade tube amp. I did this before, all passive. The stock crossover has biamp capability. It was a disaster. The bass was heavy and thick and out of balance volume wise.
You really need to get the bass right. If that's not right, if its lacking, the system can sound thin. If too much the system can sound muffled.I believe you are all correct. Blending amps is a problem. My system is too boutique. At least as far as the speaker is concerned. I have altered it on an extreme level. I have not applied all the changes that have been suggested to me by others. So I am in a limbo land.
Ralph, I bought the DSP as its $100 and it was to level match the A3cr to the Blade. I crossed it at the same point as the passive. 600 to 700 hertz. Then adjusted the gain. That's all I did. What surprised me was how sonically different the sound was between the active and passive crossover. I think. I have to listen again. I think the passive was much thicker sounding and sort of grainy. The active is more thin and less grain. Less body and warmth.
I will most likely fiddle a little. But in the end, I have to get my room in order. New flooring. Some treatments. Then use the Blade amp only, my horn sub, and then try and add a couple other subs to reach lower in hertz. I was reading in another forum how a member is using AI to great affect. The AI analyzes the plots and graphs from REW, then tells you where to move your speakers. How to toe the speaker in. Then helps integrate the subs. As in placement as well as all the DSP settings. I asked my AI if it could help and it said absolutely.
I don't see any reason why a nice little 6 channel amp and a active crossover would not give great sound. DSP might be very useful. Jason the Audiophile Junkie has raved about active for years. Another guy I know is doing the same now and at the moment is very much liking what he hears. Using this cheap Dayton DSP.
I don't know that either passive or active in the end it better. I am sensing it will come down to taste. And how involved do you want to get.
I do believe I need to get into the passive crossover and replace some of the components with better parts. I was a bit surprised how much the 15 inch woofers going to 600 hertz influence the purity and natural sound of bass. Duuuuhh, Right!!!!! Those parts need to be as good as the parts going to the 10 and the horn.
The Dayton is $200 new. A great tool to learn with. The guy I know likes it so much, he does not use the passive one with his speaker. He can't get a passive to dial in as precisely.
Why buy another crappy design tool. I have one already. I would rather spend the money on a quality crossover when ready.Get a used Behringer DCX 24/96. Extremely flexible digital crossover, no computer needed. It can also be modded to bypass the crappy op amps for a much better sound. But as a design tool it’s super easy and flexible.
What crappy design tool do you have?Why
I have read where people say, crossing in the signal is just as bad a crossing after the amp. Some like the amp side better. They say you just need a more powerful amp. Thoughts
If you don't think you need something like this to get your system dialed-in then why all this gnashing of teeth from you about how to get this right? Maybe you just need to get someone over who knows his way around active setups to help you get it right?Why
I have the Dayton DSP 408. Its super fast and easy to dial in the slope, gain, phase, crossover point. Even has a full EQ. Can cut top and bottom on a 3 way. Its a nice tool. All I am saying is why buy another tool. I have one. If I proceed, I will eventually go active analog. Like a Merchand tube. Even those need to be modified. OCD Mike has a video on how his is built. No op amps.What crappy design tool do you have?
