Tube Contact Issues
Designsfx
429
285
68
Los Angeles
Hello All-
I wanted to see if anyone here has any hands on experience/expertise in dealing with worn/age contacts like those shown on the tube pictured (Tungsram EL5).
I realize these contacts are troublesome in general with issues ranging from persistent crackling and hum to extremes of intermittent operation. Some suggest the best method of approach is to just leave it in the adapter (once you get it working) but even that has proven to be a challenge with issues of hum returning out of the blue.
I have a few of these tubes and every one has demonstrated this issue at one point or another. I can’t blame this on the tube base as they seem to be in order.
Has anyone ever attempted or made a successful repair to this type of tube? Any suggestions would be greatly appreciated.
@oldvinyl gave out some incredible information on cleaning tube pins for lowering noise that might be able to help you.
I tried cleaning tube pins using a toothbrush and rubbing alcohol and documented the changes in noise on a Maxipreamp II tube tester. That's about 10 minutes of soaking with rubbing alcohol and a few scrubs with a tooth brush. I know what was suggested would be even better.
Reactions: Designsfx
Thanks for the response! I’ll give this a read. I’m actually wondering if anyone has knowledge of reconditioning the shape of the contacts themselves, or if better suited, re-forming them. I’ve heard of some adding solder to the contacts to improve surface area but wonder if there is a method of improving the contact via some form of replacement.
You might be able to touch up the contacts by resoldering them. Extreme care is needed to only heat the contacts and not melt the base or up into the tube. There are heat sinks to attach to keep the hear just at the tip.
Cleaning the contacts AND the sockets is highly recommended. The results can be quite amazing.
So as a follow up to this I tried another method that seems to have worked very well in eliminating the “hum” and low level noised experienced with this tube.
Using a variable power supply and a wired tube adapter I drove the filament voltage up past the standard operating point. I had to be careful as I had lost a tube (that I thought was dead anyway) in a previous attempt. This was describes as a method of burning off or stripping the oxidation on the tubes filaments.
After applying a higher voltage of 15V for a brief amount of time (less than 10:seconds) I lowered the voltage while monitoring the current levels. I brought the voltage level down to the point to which the current draw stabilized at spec and left the tube operating at this mark (8V/1.3A) for 30 minutes.
I played this tube for the first time last night, I’m listening to it now and it’s virtually silent.
Reactions: Mr.Miniwatt
These are indeed excellent news, from what I know this trick of using higher filament voltages for short periods of time was used by many to revive "dead" tubes. In my case I had a dead AZ1 4V rectifier which after a few sessions of 6.3V started to work properly. Of course, those doing this advice to be around 3x heater voltage or at least much more than me, but my tester is able to do only 4/5/6.3V on heaters, I need to buy some external power supply because I have more tubes in the same situation. The fact that besides reviving it works also for hum is encouraging.
Yes- you definitely have to use caution when performing this “fix”. As you had probably heard me mention I had two EL5’s that I had thought were dead as the filaments showed no signs of energizing when the shipments were received.
I had read an article on tube reconditioning that did state that if one applied 3x the normal filament voltage the stripping process would take effect. It was the first tube I tried this on that when taken to 3x the normal operating voltage fizzled out permanently- which is a bummer because the tube did come back to life at 18V. Had I not pressed on I probably would have an operational tube.
As for the one that followed with success- it’s still installed in my Lampizator and hasn’t made any crackles or hum since.
