I have a theory on power cables. They are not the first or last point in a system, but they are an important portion. And I use the word portion for a reason. A power cord is really a jumper. It's a flexible strap with a disconnect point on both ends. This makes it unique in the power foundation of our systems. A power cord is only held in place by jaws and tension. It is not held in place with a screw and clamp. It is 2 x inferior points of contact.
In my opinion a power cord is an unfortunate requirement by the NEC. A power cord is a hindrance to high performance audio. The reason in my mind it voices so strongly is because a cord is a mesh of dissimilar metals joined together with inferior contact points. It’s a perfect storm for distorted and damaged performance potential. Being that there is potential for distortion and damage means extreme attention to detail must be taken to ensure as little damage is done as possible.
In synopsis:
With a cord there are roughly 6 points of contact where only pressure is applied to make contact between devices. Really 18 as it occurs on all 3 wires. In wall wire to receptacle, receptacle clamp to cord blade, cord blade to cord conductor, cord conductor to cord blade, cord blade to IEC inlet blade, IEC inlet blade to internal wire. There are at least as many instances where dissimilar metals are in contact with each other. Plating add even more dissimilar metal as it not only interacts with the electrons at the contact point, it is reacting with the electrons along the whole of the material the coating is applied to.
