Balanced connection makes the signal-to-noise ratio 6 dB worse. In a quality audio system, hum is taboo, so I'm surprised you gave this link. The pictures there show that they are fighting at a frequency of 50 Hz.
The line does not degrade the signal-to-noise ratio, but connecting the differential signal to the balanced input of the RIAA preamp does.Huh? balanced lines increase gain by 6db while rejecting hum, its doesnt degrade the s/n.
FWIW that's an older MP-3 in the phono. For at least 5 years now they have dual outputs.View attachment 155666
The Atma-Sphere MP3 is similar in configuration, uses only a single box and costs less. I have not heard it.
This statement is false if the connection supports the balanced standard known as AES48.But connecting a differential signal to a balanced amplifier has a very unpleasant feature: the amplitude of the signal at the amplifier inputs is divided proportionally to their input resistance, in a balanced amplifier in half. That is, 5 mV comes from the cartridge, and at the inputs of the balanced amplifier we have 2.5 mV each.
This statement is false. A balanced connection allows the receiver of the signal (in this case the phono input but could also be the connection between the balanced phono circuit and the line stage) to reject hum that is common to both inputs (inverting and non-inverting). So its more resistant to hum in this regard. If the circuit is differential, each stage of gain has up to 6dB less noise than the same circuit executed single-ended. This adds up from stage to stage and is why our balanced phono section, despite passive EQ, only has two gain stages yet can work with LOMC cartridges.Balanced connection makes the signal-to-noise ratio 6 dB worse.
The relevance to home use is obvious to anyone who has auditioned interconnect cables and heard a difference.For home use, this is not relevant, the inter-unit cables are short and there is no hum
Sheesh... staring right at it too.Actually it is/was the MP-1 I owned.
This statement is false. These are just words without any evidence. It is very easy to understand how 5 mV of a differential signal is converted into 2x2.5 mV of a balanced signal. Then simple arithmetic.This statement is false. A balanced connection allows the receiver of the signal (in this case the phono input but could also be the connection between the balanced phono circuit and the line stage) to reject hum that is common to both inputs (inverting and non-inverting). So its more resistant to hum in this regard. If the circuit is differential, each stage of gain has up to 6dB less noise than the same circuit executed single-ended. This adds up from stage to stage and is why our balanced phono section, despite passive EQ, only has two gain stages yet can work with LOMC cartridges.
These statements are entirely false. In a balanced line system the shield is ground. That is the tone arm tube.I hope you know that Balanced connection for tonearm is only a way to say "I have xlr connector". Signal is the same if you use RCA connector.
In real balanced signal for every channel you have 3 cable where two are pole and one a ground, in tonearm you have 2 pole and the cable's shield.
Especially if its a LOMC, since their source impedance is so low driving the cables. You want to keep an SUT as close to the preamp input as you can and keep the interconnect cable capacitance down since that affects the SUT loading.so its a misunderstanding that tonearmcable should be short instead of SUT to riaa cable...the balanced cart signal can better drive long cables
The signal from the cartridge is a differential signal. The tonearm does not participate in shaping the signal from the cartridge in any way.Phono cartridges are balanced sources. The reason there is that weird ground wire that no other single-ended source seems to need is you have to do something about the shield: that's the ground wire.
The noise that gets on the cable is called hum. Theoretically, it should be less than in an unbalanced cable. But there is no practical difference in the length of the cable from the cartridge to the phono amplifier. Unless this cable is 10 meters long. Have you seen this?The reason to go balanced is immunity from interconnect cable coloration (which is why there are some very expensive single-ended tone arm cables) and greater immunity to noise impinged on the cable. If there's any place in the entire system to get things right, its the front end of the system since no matter how good the preamp, amps and speakers are, they cannot make up for a loss or alteration of the signal before it even gets to the preamp!
You are right!Phono cartridges are balanced sources.
Nearly all arms are balanced. You can run a balanced line from any Dual, Garrard or BSR turntable made in the 1960s or 70s; any arm that runs a separate ground wire. Its really about the phono preamp.You are right!My mistake. MC cartridge is balanced, MM (as I read) need a modify.
Something for me is not so clear, we use balanced connection to reduce noise in a short distance (most of all hifi sistem has got turntable very close to the phono preamp) but at the same time we use tube (insted solid state that have no hum) to amplifie a very low signal.
In the gold-era of vynil this connection wasn't practiced, i think.
If is so good why is not implemented in all arms and phono preamp?
Could be like use a gun to kill a fly?
