Devialet sounds poor. Lots of people I know bought them and then sold them…I also had one in house for a couple months…dry like all the others…I did like the Devialet but in mono config only ..
Are you saying you like a class A or AB SS amp. But do not like a class D amp so much?7Yes all had bad timbre , Crown best drive bad timbre vs others. The hi freq hash is also obvious with few exceptions..
SS amps of high Quality does dverythign it toob counterparts do but better, the problem with SS people buy them and throw them in and think tjey are done , yet by a bad sounding tooby amp and spend months tweaking everything known to man to get them sounding good and when they do proclaim better to SS .
Take the same effort on selecting a pre and matching amp to speaker load when using an SS amp like you do on a toob and it will deliver..!
Wait! You spent $15k rebuilding your Audions which aren’t worth a fraction of that on the used market??Are you saying you like a class A or AB SS amp. But do not like a class D amp so much?
That was sort of why I opted to try the A3cr. Its class AB and I didn't think it could go so wrong.
But, to your point, I have not moved my speakers around. Changed speaker cables and interconnect as well as power cables. I plugged it in, attached it to my existing setup and played it about 8 hours over 3 days to let it settle. Then listened in earnest.
Who knows. Maybe it needs to be recapped. But after my last fiasco with the SET845 and $15k bleading out of my bank, I am very gun shy to rebuilding a less than optimum amp.
I have no idea what the spec sheets linked in post 83 mean as pertains to sound quality. But if they were posted with a, no wonder, type comment, then it sounds like this amp will never rise very high.
Not sure what version software etc , i heard a pr on ESL’s mono config was not dry at allDevialet sounds poor. Lots of people I know bought them and then sold them…I also had one in house for a couple months…dry like all the others…
Most audiophile SS amps are class A A/B , with a few exceptions which are low wattage full class A @8 only bias …!Are you saying you like a class A or AB SS amp. But do not like a class D amp so much?
Several versions, including 1000 pro.monos, smaller ones in stereo and mono an original, etc. corresponds pretty closely to class D I have owned and many many others I have heard besides. Your first comment was right, timbre is all wrong…always.Not sure what version software etc , i heard a pr on ESL’s mono config was not dry at all
Plenty drive , ran very hot …
Input is class A and output is class D.Thought Devialet was not Class D , they run pretty hot ..
Yes. It wasn't until recently (the last 20 years or so) that the semiconductors needed to really raise the Gain Bandwidth Product really existed.Poorly designed ones do , with enuff open loop gain and bandwidth this is not an issue…
The class of operation isn't important. The harmonic spectrum generated by the amp is.Are you saying you like a class A or AB SS amp. But do not like a class D amp so much?
Nope. Any class D has class A at its inputs if it has a decent input buffer. The Devialet runs hot because its got a small class A amplifier inside in tandem with the class D output. A least as far as their website suggests...Input is class A and output is class D.
Just a quick question: Was the Musical Fidelity new? They take a long time to break in. Super good power supply with a big choke for the price.Are you saying you like a class A or AB SS amp. But do not like a class D amp so much?
No. Not new. I am the 3rd owner?Just a quick question: Was the Musical Fidelity new? They take a long time to break in. Super good power supply with a big choke for the price.View attachment 159471
Yes. I was a stupid sucker that went back many times under the promise that this was the fix. It was a slow blead. But I was also lead to believe that SET was the best way to go. My speaker is 96db. And the 845 makes about 17 watts. So I was believing I was chasing gold. I ended up with a hunk of lead. I got Fd from start to finish.Wait! You spent $15k rebuilding your Audions which aren’t worth a fraction of that on the used market??
So, in YouTube repair videos, you often see that they have a heat problem and die. I always thought musical fidelity sounded beautiful. I always think of David Amp. It looked weird but was still a lot of fun to listen to music. It also often died from heat.No. Not new. I am the 3rd owner?
I will pop the lid and look to see if there are visible issues. I have no idea how
My backup unit is a Devialet D200 which is a class A/D hybrid. Nice sounding unit. It needs some effort to setup as you need to create a configuration file and flash it. Easy thing to do. More information at Devialetchat.com.
You are welcome to take it and play with it to see if you like it. Let me know. I am in Kirkland.
Is it easy to recap?So, in YouTube repair videos, you often see that they have a heat problem and die. I always thought musical fidelity sounded beautiful. I always think of David Amp. It looked weird but was still a lot of fun to listen to music. It also often died from heat.
Reviews from owner
Musical Fidelity A3CR Amplifiers user reviews : 4.9 out of 5 - 35 reviews - audioreview.com
Musical Fidelity A3CR Amplifiers user reviews : 4.9 out of 5 - 35 reviews - audioreview.comwww.audioreview.com
“The world’s first hybrid amplification technology delivers all the refinement of Analog amplification (Class A) with all the power and compactness of Digital amplification (Class D).Based on the same principle as advanced driver assistance, the idea of ADH is to maintain the analogue amplifier's voltage generating function (to maintain their excellent audio performance levels), while entrusting the current generation function, and accordingly, that of generating power for the load, to an amplifier equipped with drastically superior energy efficiency: in this case a digital amplifier, otherwise known as a switch amplifier.”No. ADH (Analog Digital Hybrid) is a complex scheme invented by Devialet.
See https://www.devialet.com/en-us/ampl...cWW17Q2ULXdEZ-mnmGQJWka3w_Ma0QtRbeNQb8E4wBrLK
“The world’s first hybrid amplification technology delivers all the refinement of Analog amplification (Class A) with all the power and compactness of Digital amplification (Class D).Based on the same principle as advanced driver assistance, the idea of ADH is to maintain the analogue amplifier's voltage generating function (to maintain their excellent audio performance levels), while entrusting the current generation function, and accordingly, that of generating power for the load, to an amplifier equipped with drastically superior energy efficiency: in this case a digital amplifier, otherwise known as a switch amplifier.“Yes. It wasn't until recently (the last 20 years or so) that the semiconductors needed to really raise the Gain Bandwidth Product really existed.
The tubes do very well because they can mask higher orders which the ear finds objectionable.
Sure, but i think it had nothing to do with real problem.Is it easy to recap?
Says here Class A for voltage and D for current
