Marantz 7 clone tape head preamp
You're right, I missed that change in the diagram. I'll try installing a 360 ohm resistor there. I'll check the gain and adjust it if necessary.
The preamp will work with a tube amplifier, so they should get along ;)scheme.png
Quick update:
The preamp is working, it works flawlessly. The sound is also very pleasant, but so far I don't have any screening and I connected it with thin cables, so there was some interference from the capstan motor.
Below you can see photos from the construction and an oscilloscope graph. When I fed a 1kHz; 0.1V signal into the input, I got about 3.4V at the output.
The capacitors are Mundorf ZN, the tubes are Tung-Sol, and I bought the transformer on Aliexpress together with the PCB.
I will post a few more photos later when the enclosure is ready. I also plan to add VU meters.
Thank you again for your advice on this project, I had a lot of fun :)
Reactions: tapepath
It seems to me that surprisingly Poland is a leader in production of tube head pres by Foxbat's idea.
I was lucky to spend a few days over there and play with some of my toys.
The silver one is a Marantz clone but based on different board from years back. It has two inputs with variable 50 to 200kOhms and 100pF termination. No hum or noise and very nice sound. Good tubes help a lot.
On the top of Akai is Knight KP70 and on the carpet, a black one, is a RCA based one with penthode input tube.
I use only commercial 7.5 ips reel tapes. Fast master's copies are beyond my grade. R.
I am getting close to a trial with my effort.
Quick update:
Have you connected the head block to the ground of your preamp ? This is necessary to reduce noise. I used the screw between the opening for the wires and the left roller guide to secure a connection with a ground cable via a small spade connector. This follows the output cables from the repro head back to the preamp.
Yesterday, I added to my tape recorder additional direct outputs straight from the head.
I had to use new cables because the original ones turned out to be a bit too short. I used Mogami 2697 microphone cables, which I think are ideal for this application because they have two wires and an additional shield that protects against interference.
I made the outputs using XLR connectors where pin 1 is ground, pin 2 is signal, and pin 3 is a shield connected to ground on one side.
The preamp enclosure will also be connected to the ground of the circuit, so this should ensure complete silence in the circuit.
In the evening, I will add some photos of the work I have done. (EDIT: pictures added)
@Robnec maybe it's because Polish people like to DIY and believe that they do everything best ;) (of course, I'm joking).
Reactions: Robnec
A device that I found helpful is an inverse NAB network offered by KAB Electro Acoustics. It allowed me to connect a signal generator (works best with 50 ohms output impedance) to the NAB network and look at the frequency response. Granted, it doesn't substitute for a calibration tape or a flux loop, but it can give you a beginning point at seeing the overall compliance with the NAB EQ.
https://www.mrltapes.com/
Reactions: tapepath
I found connecting the chassis to the circuit ground actually increased the noise. I therefore isolated the chassis/power supply ground from the circuit ground with a ground lift switch and it works well. Connecting the head block to the circuit ground is important.
The tape head is a balanced source FWIW, so the correct connection to a single-ended preamp is the same as you would use for a phonograph.
the obvious advantage with DIY is that you can spend the money on what is important and not BLING...also you learn a lot and get to know your components
That depends on the combination. In my experience I never do that, the head connects directly to the preamp and the cable shield is only grounded at the preamp, no connection to the recorder chassis. I have done it that way on quite a few machines.
Every machine is different. For instance, in Studer A820 no matter how you connect it the right channel always has some very small amount of residual buzz. This must have to do with their internal configuration. I have two machines and they both do exactly the same. It is a very small amount, but if you turn the gain into stratosphere and put your ear to the speaker you can hear it.
Yes, the Revox B77 has a slight hum on the right channel that disappears once I hit the play button.
Reactions: Robnec
Please explain your rationale for meters. Are you going to have the special calibration circuit for them? Because without it it is going to be pointless.
Maybe pointless but they are cool.
Build from RCA manual inside Teac 4010sl box.
Reactions: Atmasphere
Strictly novelty- the board and meters are less than $10 and I had an extra 12v tap on the in-stock transformers I had.
I will use a test tape and calibrate to that level on the VU's - this is just for visual interest.
Fine with me. What level are you going to calibrate to? This circuit has limited gain.
I will try for .775vrms for 0vu... it is just an average approximation as the meter is probably pretty slow and I am not sure of how effective the buffering cct is on the board. It will give a correlation as to how I perceive the sound- really that is all I am looking for.
Thank you for your efforts in providing this to the community!
I will have to experiment. Just all in fun.
I agree, this is all about fun. I always have some meters ON when listening to music... plus the scope in its XY mode. :)
Reactions: Kcin
