A tempus landed here a little over an hour ago. I honestly can’t believe that a switch could have such a profound impact - especially in the terms of realism. Unbelievable.
Got that Veridion Discover PC on it?A tempus landed here a little over an hour ago. I honestly can’t believe that a switch could have such a profound impact - especially in the terms of realism. Unbelievable.
Yes that’s what’s powering it. A Veridion Discovery Ethernet cable exits it as well. Fiber is incoming but more Discover has been purchased to replace the fiber.Got that Veridion Discover PC on it?
I have found NA's streaming cables, which BTW are no joke, really excel when paired with eno2, muon pro or Tempus.Yes that’s what’s powering it. A Veridion Discovery Ethernet cable exits it as well. Fiber is incoming but more Discover has been purchased to replace the fiber.
I am sure they are excellent. What one gets from a $250 investment in a Discovery Veridion is astonishing though. I found that I preferred it to a Shunyata Sigma. At some point I may still want to try one of NA’s streaming cables.I have found NA's streaming cables, which BTW are no joke, really excel when paired with eno2, muon pro or Tempus.
is it the only switch in your setup for this test?A tempus landed here a little over an hour ago. I honestly can’t believe that a switch could have such a profound impact - especially in the terms of realism. Unbelievable.
Is this just with the Tempus? No additional filters?A tempus landed here a little over an hour ago. I honestly can’t believe that a switch could have such a profound impact - especially in the terms of realism. Unbelievable.
Yes just tempus with no additional filters. Fiber feeds the tempus though so there is some isolation.Is this just with the Tempus? No additional filters?
I have been going around on the idea of a new switch. Streamed music as is, is not much different than what I get from HQ player, with or without the ethernet cable plugged in. I have tried this. That to me means adding better and better network equipment isn't going to make my streaming much better as its already very close to my stored files. Only a transport might up the whole experience. Correct?
Dedicated Mojo Audio server, usb to Mojo Audio DAC. Server and DAC both have independent power supplies for the USB.What is your current setup? I'm assuming laptop/PC using HQ Player / streaming service directly via USB to your DAC?
If so, you'll be better served by a streamer than network devices, yes.
News dropped today that a much more affordable version will drop soon. See this.Probably a bit cruel on my part to mention this extension since it’s no longer available and nothing has replaced it at that price - the latest iteration is 4x as expensive.
Looking good bet it sounds great!When my tempus first landed a couple weeks ago, I had no room on my rack for it, so I just set it on a bamboo cutting board laid on top of a Shunyata Typhon (original). The Typhon itself has the optional SSF-38 feet and these sit on another bamboo board. Not ideal but not the worst starting point.
A few nights ago I shuffled things around so the tempus would get a shelf to itself on my rack. Stillpoints Ultra SS are under the tempus and under the tempus power supply are some MoFi footers that I only just learned about as they were advertised as discounted on one of their emails. My original Denali power conditioner went to the floor to free up that space on my rack for the tempus. I also used this opportunity to better organize the cables behind my rack, taking more care to keep power cables away from signal cables.
To my surprise, this reconfiguration brought a very noticeable improvement in sound quality. Too many things changed so l can’t say what should get credit. Part of it could be from the tempus settling in further, but it gaining its own shelf I would think helped too. There’s actually a Stillpoints Aperture panel hanging on the wall behind my rack, so I’m also thinking that having the Denali on that shelf might have been limiting the panel’s effectiveness. I can’t say - but this just further shows how much everything matters in this hobby.
I’m curious if an other tempus owners have any insight into whether stacking the power supply on top is a suboptimal way to go.
I don’t recommend stacking power supply. Actually, it is very sensitive to footer than the switch itself.When my tempus first landed a couple weeks ago, I had no room on my rack for it, so I just set it on a bamboo cutting board laid on top of a Shunyata Typhon (original). The Typhon itself has the optional SSF-38 feet and these sit on another bamboo board. Not ideal but not the worst starting point.
Imagine some people stream their whole lives without treating their network delivery chain. Boggles my mind why they won't even try to prove they're right.It goes against almost everything you read on the internet about networking and that it either works, or it doesn't. There is no grey area and nothing can change the 1s and 0s for better, or worse - except a bad cable or switch. Well, I can honestly say that's complete rubbish.
