Cube Audio is not a great speaker, but with the right amps it can sing. The O/96 isn’t very different in that regard. Both have strong character—I know because I’ve owned them both.It can, depends on the speaker. If you need the 18watts, it is a different speaker. If you do 18w Mayer or anything else vs the 46 on that Pnoe, you will lose nuance, speed. It depends on the speaker of course.
Same while compaaring with Devore and Cessaro Wagner in same room, it was quite clear the Wagner needed higher reserve, would compress on lower reserve, while putting the same amps on the O96, the lower watt amp was quite superior to the higher watt amp without any compression (at that time it s Airtight 300b vs Airtight El34)
Or comparing Devore to Lansche in same room with variety of amps, a similar case was true.
if your speaker is showing more headroom with the 18w than the 2w, that is true for that speaker, not for others. Cube audio is quite poor quality compared to Pnoe AER BD4/5
I don’t listen to them either, put them aside. Stenheim Alumine Five is far better than those and also more efficient which is surprising.
Last but not least: the higher the efficiency, the harder it becomes to keep a speaker’s tonal balance under control. Yes, it gets easier to drive, but the frequency response often tilts to one side, becomes harsh, or exaggerates its own character. At that point, the smallest details matter—wiring, parts quality, driver matching, everything.
Some people try to “fix” these issues by creating a new problem: using low-quality, old, or overly long cables. The bottlenecks such as resistance from those parts may mask the anomalies of high efficiency, but then you’re just left with the character of bad cables and poor parts instead. Of course a properly made and well balanced high efficiency speaker is great but is hard to achieve.
